06-03-2014 04:40 AM - edited 03-07-2019 07:37 PM
I did not find any information concerning this.
Would be great if anybody could send me a link to the information how many span ports are supported on the new Cat68 series.
Thorsten Steffen
Solved! Go to Solution.
06-03-2014 08:23 AM
For sup2t
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/config_guide/sup2T/15_1_sy_swcg_2T/span_rspan_erspan.html
Naveen
****Rate if it is helpful****
06-03-2014 08:23 AM
For sup2t
Naveen
06-03-2014 11:32 PM
Can you explain the limits?
Am I right that only two different sessions "mon sess x source interface <interface-string> both" are supported?
06-04-2014 10:13 PM
check this link, which has many examples for Span configuration on SUP2T
Naveen
