4500x does not have "switch" command
jay mamaradlo
I'm attempting to setup VSS pair on 4500x. 1 of the 2 switches appear to missing some commands:
On my Switch 1 this is the code:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.03.02.SG RELEASE SOFTWARE (fc1)
Directory of bootflash:/
31682  -rw-   112660260  Dec 13 2013 15:52:45 +00:00  cat4500e-universal.SPA.03.03.02.SG.151-1.SG2.bin
On Switch 2 that appears to be running fine is running:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.02.SG RELEASE SOFTWARE (fc1)
CR-CYL-DC-SWC-02#dir bootflash:
158402  -rw-   121703744  Nov 25 2013 02:56:07 +00:00  cat4500e-universal.SPA.03.04.02.SG.151-2.SG2.bin
On Switch 1 when i attemp to create VSS, I get the following:sw
Switch(config)#switch ?
% Unrecognized command
is this switch set in a particular mode that's preventing or do i have a bad code loading.. ? please advise..
josephsmar1
After taking a look at the current IOS on the switch I do not see VSS mentioned in the release notes. You may need to move up to a newer IOS version to solve this issue. The very next IOS 3.4.4SG seems to support VSS.
http://software.cisco.com/download/release.html?mdfid=283904596&softwareid=282046477&release=3.3.2SG
