4500X - GLC-T ONLY works if cut down to 100 Mbps
kylebrogers
Level 4
Level 4
I have a new 4500X and a new GLC-T.  The 4500X recognizes when I insert and remove the GBIC.  However, the port its in will only change to UP if I set the speed to 100.  It refuses to come up if I leave it at the default.  I need to get the full 1000 Mbps out of the GLC-T.  Has anyone else run into this issue?
You can see the status of the port below.  The moment I put "speed 100" on the port,
Running 03.08.01.E code
show inventory:
NAME: "TenGigabitEthernet1/1/15", DESCR: "1000BaseT"
PID: Unspecified , VID: , SN: AGM2016419F
Note:  The GLC-T was ordered from Cisco.  The "PID: Unspecified" threw me for a minute but apparently different manufacturers (for Cisco) put in different info.
sh run int t1/1/15
Building configuration...
Current configuration : 99 bytes
interface TenGigabitEthernet1/1/15
switchport trunk native vlan 999
switchport mode trunk
end
<HOSTNAME>#sh int t1/1/15
TenGigabitEthernet1/1/15 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet Port, address is e00e.da7b.a78e (bia e00e.da7b.a78e)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 1000BaseT
input flow-control is off, output flow-control is off
Last input 00:27:10, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
527 packets input, 45530 bytes, 0 no buffer
Received 516 broadcasts (514 multicasts)
1092 packets output, 87906 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Here is what happens when I change the speed to 100:
<HOSTNAME>(config-if)#speed 100
<HOSTNAME>(config-if)#exit
<HOSTNAME>(config)#exit
TenGigabitEthernet1/1/15 is up, line protocol is up (connected)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Full-duplex, 100Mb/s, link type is auto, media type is 1000BaseT
Last input 00:30:13, output never, output hang never
5 minute input rate 2000 bits/sec, 2 packets/sec
5 minute output rate 5000 bits/sec, 5 packets/sec
677 packets input, 63048 bytes, 0 no buffer
Received 663 broadcasts (569 multicasts)
1323 packets output, 108476 bytes, 0 underruns
looking at the problem again, and since your port stays down/down when set to 1Gbit, but up when set to 100Mbit, I am thinking that inadvertently you might be using a Cat5 and not a Cat5e cable, the first one being able to handle speeds up to FastEthernet, the second one being able to handle 1Gbit.
7 Replies 7
There used to be a hidden command, 'service unsupported-transceiver', not sure if that is still available.
Which supervisor do you have ? I think there is a limit on the amount of Gigabit (4) and TenGigabit (2) ports supported...
I gave the 'service unsupported-transceiver' a shot.  The command is still there, but it didn't fix the issue.  I think it recognizes it because it works at lower speeds.
I'm using the 4500X as opposed to a 4500 blade chassis that has supervisor blades.  So it's just a 1U, 16-port, all 10G switch.
I have 2 of them connected over a pair of 10G Twinax cables (running VSS so it acts like one switch).  Aside from those two twinax cables, the GLC-T GBIC is the only thing occupying a slot.  This is a new installation and isn't in production yet.
I cannot find anything that points to any sort of limitation, but since your switches are not in production yet, I wonder if the port behaves the same in a non-VSS configuration, can you test that, to connect the port in a standalone setup ?
I had tested it with 3 different cables just to make sure it wasn't a cabling issue.  After downgrading the code and having the same issue, I got a brand new CAT6 cable and it worked.  I don't have many CAT5(not e) cables.  It looks like I just had a bad string of luck in selecting my cables to test with.
Rytis Urnezius
First of all i suggest to check cable, then changing GLC-T to another one, or test the same one on another device.
Finally i suggest to downgrade sw to cat4500e-universalk9.SPA.03.06.04.E.152-2.E4.bin (i'm running this one with GLC-T and i don't have any problems).
The same problem is discussed at this topic:
https://supportforums.cisco.com/discussion/12942111/1000base-t-glc-t-connected-sfp-interface-4500x-running-030702e-not-working
it confirms that GLC-T stopped working at 1gbps from sw >=03.07.xx
