WS-C3850-32XS-S Command Issue
Joseph Ritchey
Hi All,
I have a Catalyst 3850 XS that I'm trying to set up and is running SW Version IOS XE 3.7.4E.  I am trying the two following commands:
exception memory ignore overflow io
exception memory ignore overflow processor
"exception" is valid but "memory" is not.  The commands work on many of my L3 switches with an older IOS.  I have been searching high and low to find an answer as to why the commands are not working, but most of the documentation says they should work.  Can anyone shed some light on this for me?
Joe
Hi Joseph,
I tried this command on a multi-gig 3850 and a regular 10/100/1000 POE 3850 and it does not work.  If the commands were never supported by this platform, than I don't think there is any documentation indicating that.
.HTH
6 Replies 6
Mark Malone
Are your older L3 switches ios-xe as I thought those commands were only in ios 3k series switches
If there not there then there unlikely supported in your version
Hi Mark.  The other L3 switches are not on XE.  I'm pretty sure you are correct that the commands are not supported, but I was trying to find some kind of documentation that stated this.  Thank you for the reply.
Are you sure the other devices are 3850 switches?
I can do this command in routers (ASR) but not 3850s
exception memory ignore overflow io frequency
Hi Reza,
The other L3 switches are not 3850s.  I have seen this command referenced for the ASRs and in Cisco's "hardening routers and switches", but I was looking for some confirmation or reference that this command will not work.  I know at this point that it most likely will not, but I haven't found the documentation as to why, or when it stopped being supported, if it ever was on the 3850s.  Thank you for your time.
Hi Joseph,
.HTH
Thank you for the information.  I appreciate the time you took on this.
