4500x stacking
jack-wilson
Wondering if there are any real worlde issues with stacking a pair of 4500X?
Data sheet says: 4500x Number of stackable switches in VSS Up to 2
Standard Stackwise cable ok? Any config or install issues? thanks
Kelvin Willacey
Level 4
Level 4
VSS and stacking are different even though they provide the same advantages. VSS is what is supported on the 4500X switches. No stacking cables are required, however a Virtual Switch Link is and this needs to be either two 10 Gbps or two 1 Gbps links bundled in an etherchannel.
As far as issues or caveats I wouldn't be able to comment, I don't have any experience with it.
paolo bevilacqua
Wrong forum, post in "LAN and switching". You can move your posting with the Actions panel on the right.
