4500X VSS Unexpected reload of both switches
FuadG
Hello everyone,
We have a VSS pair of 4500x switches that started to reload once in day, standby and active both reloading separately
IOS version is Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.06.03.E RELEASE SOFTWARE (fc3)
The error says: Last reload reason: Critical software exception
Interestingly, there is no crashinfo being generated
Directory of bootflash:/
126722 -rwx 178257396 Jan 29 2016 06:06:04 +04:00 cat4500e-universalk9.SPA.03.06.03.E.152-2.E3.bin
126723 -rw- 7425 Mar 14 2016 05:18:17 +04:00 RUN-IPadd.txt
126724 -rw- 10373 Mar 14 2016 07:01:57 +04:00 startup-config.converted_vs-20160314-030157
126725 -rw- 17069 Oct 11 2016 04:55:03 +04:00 startup-config.saved_vs-20161011-005503
126726 -rw- 17170 Oct 13 2016 11:39:56 +04:00 prePAGP.txt
Directory of slavebootflash:/
126722 -rwx 178257396 Jan 29 2016 06:04:58 +04:00 cat4500e-universalk9.SPA.03.06.03.E.152-2.E3.bin
126723 -rw- 7595 Mar 14 2016 05:19:16 +04:00 RUN-IPadd.txt
126724 -rw- 10457 Mar 14 2016 07:03:22 +04:00 startup-config.converted_vs-20160314-030322
126725 -rw- 10457 Mar 14 2016 07:09:46 +04:00 startup-config.saved_vs-20160314-030946
This VSS pair has been working fine for 6 years now, the problem started a couple of days ago
BCT-VSS-01 uptime is 6 years, 9 weeks, 4 days, 8 hours, 44 minutes
Uptime for this control processor is 39 minutes
Seems like this is not a hardware issue since both of them are reloading.
What do you think?
Thank you in advance
@FuadG wrote:
What exactly in the DHCP packets is triggering this?
The crash is caused by the DHCP daemon.  I don't work for Cisco so I cannot provide any clue as to why this is just happening now after several years of uptime.
The fix is to upgrade the firmware.   Upgrade to either 3.8.10 or 3.11.7.
14 Replies 14
marce1000
 - Look into https://software.cisco.com/download/home/284867339/type/282046477/release/3.11.7E  , check if upgrading help , I tend to make abstraction on a current appearing issue because it can always come from outside such as induced by a networking issue (or client traffic) ,
 M.
balaji.bandi
Unfortunately, there are no crash logs we see on the switches. when rebooted, what logs you noticed on the switches? what was the recent changes ?
what sup module you have? how many in each chassis?
BB
When rebooted, just ordinary VSS failover logs and interfaces going up and down
Pls see the modules info below
Switch Number: 1 Role: Virtual Switch Standby
Chassis Type : WS-C4500X-16
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 16 4500X-16 10GE (SFP+) WS-C4500X-16 JAE20030D4A
M MAC addresses Hw Fw Sw Status
1 00c8.8b31.0640 to 00c8.8b31.064f 1.1 15.0(1r)SG11 03.06.03.E Ok
Mod Redundancy role Operating mode Redundancy status
1 Standby Supervisor SSO Standby hot
Switch Number: 2 Role: Virtual Switch Active
1 16 4500X-16 10GE (SFP+) WS-C4500X-16 JAE20030AUT
1 00c8.8b30.e240 to 00c8.8b30.e24f 1.1 15.0(1r)SG11 03.06.03.E Ok
1 Active Supervisor SSO Active
Leo Laohoo
Post the complete output to the following commands:
  1. dir crashinfo:
  2. dir slavecrashinfo:
  3. sh log on up detail
Hello Leo,
dir crashinfo:
Directory of crashinfo:/
58466 -rw- 0 Feb 16 2023 19:16:01 +04:00 cilogs
58467 -rw- 0 Jan 29 2016 05:27:05 +04:00 koops.dat
58468 -rw- 192 Feb 16 2023 19:13:27 +04:00 deleted_crash_files
58469 -rwx 3881765 Feb 16 2023 19:13:27 +04:00 crashinfo_iosd_20230216-151157-UTC
58470 -rw- 44 Feb 16 2023 19:13:28 +04:00 last_crashinfo
58471 -rwx 67468601 Feb 16 2023 19:13:28 +04:00 fullcore_iosd_20230216-151157-UTC
58472 -rwx 3926504 Sep 30 2022 03:59:06 +04:00 crashinfo_iosd_20220929-235735-UTC
58473 -rwx 68408336 Sep 30 2022 03:59:07 +04:00 fullcore_iosd_20220929-235735-UTC
58474 -rwx 3894207 Feb 13 2023 06:00:24 +04:00 crashinfo_iosd_20230213-015854-UTC
58475 -rwx 68149154 Feb 13 2023 06:00:25 +04:00 fullcore_iosd_20230213-015854-UTC
dir slavecrashinfo:
Directory of slavecrashinfo:/
62498 -rw- 0 Feb 16 2023 20:39:11 +04:00 cilogs
62499 -rw- 0 Jan 29 2016 05:27:17 +04:00 koops.dat
62500 -rw- 576 Feb 16 2023 20:36:47 +04:00 deleted_crash_files
62501 -rwx 3916846 Feb 16 2023 20:36:47 +04:00 crashinfo_iosd_20230216-163517-UTC
62502 -rw- 44 Feb 16 2023 20:36:47 +04:00 last_crashinfo
42337 -rwx 67380146 Feb 16 2023 20:36:48 +04:00 fullcore_iosd_20230216-163517-UTC
62504 -rwx 3933106 Oct 25 2022 08:17:37 +04:00 crashinfo_iosd_20221025-041607-UTC
62505 -rwx 68160469 Oct 25 2022 08:17:38 +04:00 fullcore_iosd_20221025-041607-UTC
62506 -rwx 3922734 Feb 14 2023 12:51:50 +04:00 crashinfo_iosd_20230214-085019-UTC
62507 -rwx 67841300 Feb 14 2023 12:51:50 +04:00 fullcore_iosd_20230214-085019-UTC
show log onboard uptime detail
Executing the command on VSS member switch role = VSS Active, id = 2
UPTIME SUMMARY INFORMATION
First customer power on : 01/17/2016 21:09:17
Total uptime : 6 years 48 weeks 4 days 2 hours 25 minutes
Total downtime : 0 years 8 weeks 1 days 10 hours 46 minutes
Number of resets : 42
Number of slot changes : 2
Current reset reason : 0x9
Current reset timestamp : 02/16/2023 19:20:30
Current slot : 11
Current subslot : 0
Current uptime : 0 years 0 weeks 0 days 15 hours 0 minutes
Reset | |
Reason | Count |
No historical data to display
UPTIME CONTINUOUS INFORMATION
Time Stamp | Reset | Uptime
MM/DD/YYYY HH:MM:SS | Reason | years weeks days hours minutes
01/17/2016 21:09:17 0x0 0 0 0 0 0
01/17/2016 21:17:21 0x0 0 0 0 0 0
01/29/2016 05:29:35 0x0 0 0 0 0 20
01/29/2016 05:48:35 0x9 0 0 0 0 5
01/29/2016 06:13:16 0x0 0 0 0 0 0
01/29/2016 06:29:33 0x0 0 0 0 0 0
03/14/2016 04:21:39 0x0 0 0 0 0 0
03/14/2016 04:55:21 0x0 0 0 0 0 20
03/14/2016 07:10:09 0x9 0 0 0 2 0
03/28/2016 07:46:46 0x0 0 1 6 23 0
05/24/2016 07:28:38 0x9 0 8 0 23 0
05/24/2016 08:15:45 0x9 0 0 0 0 20
05/25/2016 02:21:35 0x9 0 0 0 17 0
05/25/2016 05:47:56 0x9 0 0 0 0 30
05/25/2016 05:58:39 0x0 0 0 0 0 0
05/25/2016 06:17:10 0x0 0 0 0 0 5
05/25/2016 06:44:05 0x9 0 0 0 0 15
05/25/2016 07:27:06 0x0 0 0 0 0 20
05/25/2016 07:51:37 0x9 0 0 0 0 15
05/25/2016 08:04:22 0x9 0 0 0 0 5
05/25/2016 08:16:08 0x9 0 0 0 0 5
05/25/2016 08:47:05 0x9 0 0 0 0 20
05/25/2016 09:28:04 0x9 0 0 0 0 30
10/10/2016 08:42:58 0x0 0 19 4 23 0
10/10/2016 09:36:03 0x0 0 0 0 0 15
10/10/2016 09:50:59 0x0 0 0 0 0 5
10/10/2016 10:06:20 0x9 0 0 0 0 5
10/11/2016 04:06:30 0x9 0 0 0 17 0
10/13/2016 08:56:14 0x0 0 0 2 4 0
10/13/2016 18:20:26 0x9 0 0 0 1 0
10/13/2016 18:48:21 0x9 0 0 0 0 20
10/13/2016 19:09:10 0x9 0 0 0 0 10
12/12/2016 12:32:11 0x9 0 8 3 17 0
12/17/2016 14:27:23 0x9 0 0 5 1 0
07/12/2017 19:32:58 0x9 0 29 4 4 0
07/12/2017 19:43:46 0x9 0 0 0 0 0
05/03/2019 21:44:07 0x9 1 42 1 1 0
03/06/2021 11:49:41 0x0 1 43 6 13 0
03/06/2021 11:58:59 0x0 0 0 0 0 0
09/30/2022 04:05:58 0x9 1 29 4 15 0
02/13/2023 06:07:21 0x9 0 19 3 1 0
02/16/2023 19:20:30 0x9 0 0 3 13 0
Executing the command on VSS member switch role = VSS Standby, id = 1
First customer power on : 01/17/2016 21:09:20
Total uptime : 6 years 48 weeks 4 days 2 hours 15 minutes
Total downtime : 0 years 8 weeks 1 days 18 hours 44 minutes
Number of resets : 44
Number of slot changes : 1
Current reset timestamp : 02/16/2023 20:43:33
Current slot : 1
Current subslot : 0
Current uptime : 0 years 0 weeks 0 days 14 hours 0 minutes
Reset | |
Reason | Count |
01/17/2016 21:09:20 0x0 0 0 0 0 0
01/17/2016 21:17:24 0x0 0 0 0 0 0
01/29/2016 05:29:46 0x0 0 0 0 0 20
01/29/2016 05:47:40 0x9 0 0 0 0 5
01/29/2016 06:12:26 0x0 0 0 0 0 0
01/29/2016 06:28:40 0x0 0 0 0 0 0
03/14/2016 01:40:38 0x0 0 0 0 0 0
03/14/2016 02:37:53 0x0 0 0 0 0 10
03/14/2016 07:09:13 0x9 0 0 0 4 0
03/28/2016 07:00:53 0x0 0 1 6 23 0
05/01/2016 23:17:49 0x0 0 4 6 16 0
05/24/2016 07:29:57 0x0 0 3 1 8 0
05/24/2016 08:23:13 0x9 0 0 0 0 40
05/25/2016 06:34:31 0x9 0 0 0 22 0
05/25/2016 06:57:26 0x9 0 0 0 0 15
05/25/2016 09:27:09 0x9 0 0 0 2 0
10/10/2016 08:42:09 0x0 0 19 4 23 0
10/10/2016 09:13:12 0x0 0 0 0 0 15
10/11/2016 04:05:39 0x9 0 0 0 18 0
10/11/2016 04:18:44 0x9 0 0 0 0 5
10/11/2016 04:55:26 0x9 0 0 0 0 30
10/11/2016 16:20:50 0x0 0 0 0 3 0
10/13/2016 08:55:20 0x0 0 0 2 0 0
10/13/2016 18:40:32 0x0 0 0 0 1 0
10/13/2016 18:56:50 0x9 0 0 0 0 5
12/12/2016 12:31:20 0x9 0 8 3 17 0
12/17/2016 13:02:32 0x9 0 0 5 0 0
05/27/2017 16:32:00 0x9 0 23 0 3 0
07/13/2017 10:06:01 0x9 0 6 4 17 0
08/31/2017 03:21:33 0x0 0 6 6 16 0
12/12/2017 22:50:57 0x0 0 14 5 19 0
07/03/2018 00:30:56 0x0 0 28 6 1 0
07/03/2018 03:04:14 0x0 0 0 0 0 10
07/03/2018 03:41:33 0x0 0 0 0 0 30
07/03/2018 04:41:59 0x0 0 0 0 0 10
07/03/2018 19:50:23 0x0 0 0 0 14 0
07/20/2018 22:57:32 0x0 0 2 3 2 0
01/27/2019 13:09:27 0x0 0 27 1 13 0
04/07/2019 09:10:50 0x0 0 9 6 19 0
02/13/2021 21:36:09 0x9 1 44 5 12 0
02/23/2022 08:25:50 0x9 1 1 2 10 0
10/25/2022 08:24:35 0x9 0 34 5 23 0
02/14/2023 12:58:47 0x9 0 16 0 4 0
02/16/2023 20:43:33 0x9 0 0 2 7 0
@FuadG
58475 -rwx 68149154 Feb 13 2023 06:00:25 +04:00 fullcore_iosd_20230213-015854-UTC​
That's a lot of crash files!
From the primary supervisor card, please attach these files so we can have a peep.
Hello Leo,
Please find attached the files you requested.
      - You may for instance also connect to your device(s) with  https://cway.cisco.com/cli/ , then at the top left you can run 'System Diagnostics' at the top right you can run 'Crashdump Analyzer'
 M.
@FuadG wrote:
IOSD-EXT-SIGNAL: Segmentation fault(11), Process = DHCPD Receive
Even matches the IOS version:  CSCuy18386
NOTE:  IOS version 15.2(2)E3 equates to IOS-XE version 3.6.3.
Hello Leo,
Thank you for your efforts but we do not run any DHCP server on VSS
Are there any "ip helper-address" commands?
Yes, sure. What exactly in the DHCP packets is triggering this? The configuration for this VSS was working fine for years
Another thing:  Currently, the VSS pair is running IOS-XE version 3.6.- Last digit (highlighted in RED) is a "3".
Personally, I would never use an IOS/IOS-XE version with a last digit of 0, 1, 2 or 3.  I would start considering an IOS/IOS-XE version that starts with 4 and higher.
Take, for example, IOS-XE version 3.8.10 or 3.11.7.
Last thing, whether or not you are going to upgrade, I'd recommend downloading these two firmware files now while it is still possible.
