4503-E Keeps rebooting for Unknown Reason
Amro BaniHani
Dear All,
Could you please help in finiding why my switch keeps rebooting every 8-12 hours , so please please find below some helpful output waiting for your kind help
Show version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 12:19 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12C41C68
ROM: 12.2(44r)SG5
Darkside Revision 4, Nexu Revision 9, Fortooine Revision 1.22
SCHQ-DSW-02 uptime is 6 hours, 22 minutes
System returned to ROM by reload
System restarted at 10:54:47 UAE Wed Aug 21 2013
System image file is "bootflash:cat4500e-ipbasek9-mz.122-54.SG1.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4503-E (MPC8548) processor (revision 8) with 524288K bytes of memory.
Processor board ID SPE135100LX
MPC8548 CPU at 1GHz, Supervisor 6L-E
Last reset from Reload
2 Virtual Ethernet interfaces
64 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Log Buffer (4096 bytes):
*Aug 21 06:55:43.783: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Aug 21 06:55:44.659: Unable to load pkcs11 crypto engine support for TLS
*Aug 21 06:55:45.427: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-X45-SUP6L-E S/N: JAE1352S7U7 Hw: 1.0) is online
*Aug 21 06:55:45.427: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 2 (WS-X4648-RJ45V+E S/N: JAE1351RHUQ Hw: 2.0) is online
*Aug 21 06:55:45.427: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X4606-X2-E S/N: JAE1346NT4D Hw: 1.1) is online
000006: *Aug 21 10:55:46.383 UAE: %SYS-6-CLOCKUPDATE: System clock has been updated from 06:55:46 UTC Wed Aug 21 2013 to 10:55:46 UAE Wed Aug 21 2013, configured from console by console.
000007: *Aug 21 10:55:47.315 UAE: %SW_VLAN-6-VTP_DOMAIN_NAME_CHG: VTP domain name changed to ''.
000008: *Aug 21 10:55:47.439 UAE: %SYS-5-CONFIG_I: Configured from memory by console
000009: *Aug 21 10:55:47.660 UAE: %SYS-5-RESTART: System restarted --
000010: *Aug 21 10:55:47.880 UAE: %SSH-5-ENABLED: SSH 1.99 has been enabled
000011: *Aug 21 10:55:47.880 UAE: %NTP-6-RESTART: NTP process starts
000012: *Aug 21 10:55:48.136 UAE: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.40.10.38 Port 514 started - CLI initiated
000013: *Aug 21 10:55:51.336 UAE: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.40.10.39 Port 514 started - CLI initiated
000014: *Aug 21 10:56:23.112 UAE: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=3 Port=1: Transceiver has been inserted
000015: *Aug 21 10:56:24.112 UAE: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=3 Port=2: Transceiver has been inserted
000016: *Aug 21 10:56:25.112 UAE: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=3 Port=3: Transceiver has been inserted
000017: *Aug 21 10:56:26.112 UAE: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=3 Port=4: Transceiver has been inserted
000018: *Aug 21 10:56:26.880 UAE: %NTP-6-PEERREACH: Peer 10.40.10.161 is reachable
000019: *Aug 21 10:56:27.855 UAE: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:56:26 UAE Wed Aug 21 2013 to 10:56:27 UAE Wed Aug 21 2013, configured from NTP by 10.40.10.161.
000020: .Aug 21 10:56:28.087 UAE: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=1: Transceiver has been inserted
000021: .Aug 21 10:56:30.087 UAE: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=2: Transceiver has been inserted
000022: .Aug 21 10:56:30.087 UAE: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=3 Port=5: Transceiver has been inserted
000023: .Aug 21 10:56:33.351 UAE: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.40.10.39 Port 514 started - reconnection
000024: .Aug 21 10:56:38.351 UAE: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.40.10.38 Port 514 started - reconnection
000025: Aug 21 10:57:00.855 UAE: %NTP-5-PEERSYNC: NTP synced to peer 10.40.10.161
000026: Aug 21 10:57:00.855 UAE: %NTP-6-PEERREACH: Peer 10.40.10.161 is reachable
000027: Aug 21 10:58:56.989 UAE: %AAA-3-DROPACCTFAIL: Accounting record dropped, send to server failed: system
000028: Aug 21 10:58:56.989 UAE: %SNMP-5-COLDSTART: SNMP agent on host SCHQ-DSW-02 is undergoing a cold start
000029: Aug 21 11:37:39.085 UAE: %SEC_LOGIN-1-QUIET_MODE_ON: Still timeleft for watching failures is 3 secs, [user: xxx] [Source: 10.40.10.39] [localport: 22] [Reason: Login Authentication Failed - BadPassword] [ACL: sl_def_acl] at 11:37:39 UAE Wed Aug 21 2013
000030: Aug 21 11:40:59.088 UAE: %SEC_LOGIN-5-QUIET_MODE_OFF: Quiet Mode is OFF, because block period timed out at 11:40:59 UAE Wed Aug 21 2013
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4503-E 3 slot switch "
PID: WS-C4503-E        , VID: V01  , SN: SPE135100LX
NAME: "Linecard(slot 1)", DESCR: "Supervisor 6L-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports"
PID: WS-X45-SUP6L-E    , VID: V01  , SN: JAE1352S7U7
NAME: "TenGigabitEthernet1/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V03  , SN: FNS13480S6L
NAME: "TenGigabitEthernet1/2", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V03  , SN: FNS13480NJU
NAME: "Linecard(slot 2)", DESCR: "10/100/1000BaseT (RJ45)+V E Series with 48 10/100/1000 baseT Premium PoE ports (Cisco/IEEE)"
PID: WS-X4648-RJ45V+E  , VID: V05  , SN: JAE1351RHUQ
NAME: "Linecard(slot 3)", DESCR: "10GE (X2), 1000BaseX (SFP) with 6 10GE X2 ports"
PID: WS-X4606-X2-E     , VID: V02  , SN: JAE1346NT4D
NAME: "TenGigabitEthernet3/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V03  , SN: FNS13510VMM
NAME: "TenGigabitEthernet3/2", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V03  , SN: FNS13510VLQ
NAME: "TenGigabitEthernet3/3", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V03  , SN: FNS135116KA
NAME: "TenGigabitEthernet3/4", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V03  , SN: AGA1344XUK9
NAME: "TenGigabitEthernet3/5", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V03  , SN: AGA1344XUK8
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4593-E        , VID: V02  , SN: SPE135100HG
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 1000W )"
PID: PWR-C45-1000AC    , VID: V05  , SN: AZS13460HXM
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 1000W )"
PID: PWR-C45-1000AC    , VID: V05  , SN: AZS13460HX1
Please note that there was twin gig converter installed in Ten 3/6 but without SFPs.
Amro
9 Replies 9
Eduardo Cesaro
Dear Amro,
You checked if your supervisor is not problems with high processing? The "fans" in power supply is operating normally?
Please check processing using the command:
sh processes cpu history
And then check if the processing is normal then check if the Power Supply have some "red light"
Let us together try to solve this
Dear Eduardo,
Thank you for the rapid relpy, please find below the cpu utilization history
    5555566666444445555555555555555555599999444445555544444555
100
90
80
70
60
50
40
30
20
10 **********     *************************     *****     ***
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
                                         1  1      1
    6676696696696696585596696696697676996076177966716966966966
100
90
80
70
60
50
40
30
20
10 #*#**#**#**#**#**#**#**#**#*****#**#*##*#*****##*#**#**#**
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    1111111164
    1222231821
100
90
80
70
60         *
50         *
40         **
30         **
20        ***
10 ********#*
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
Leo Laohoo
Sounds like you have a power problem.
Can you describe how you power up your chassis?  Does this chassis have two PS active?  If yes, can you elaborate if one of your two PS is on UPS or not?
Dear Leo,
Thank you for the support, I have two power supplies and both of them are connected to the UPS.
Ok, that eliminates power ...
Can you check to see if your line cards are securely fastened?
I cecked all the line cards, all of them are fastened tightly, this problem is bugging me now it keeps rebooting randomly, after 10 hours, 50 minutes, 3 hours, please suggest something
InayathUlla Sharieff
Amro,
Best link to troubleshoot high cpu on cat4500 device:
http://www.cisco.com/en/US/customer/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
Inayath
I don't believe it is a cpu issue
Check your supervisor card for any sign of crashinfo file(s) and/or sub-directories.
Wait ... BOTH of your PS are connected to UPS?  The SAME UPS?
Put one of your PS connected to raw power and observe.
