4506E why not mls qos trust dsp on Gig3/2?
Jason Aarons
Level 6
Level 6
FLLUTZMDF#config t
Enter configuration commands, one per line.  End with CNTL/Z.
FLLUTZMDF(config)#int gig3/2
FLLUTZMDF(config-if)#mls qos trust ?
% Unrecognized command
FLLUTZMDF(config-if)#mls qos ?
FLLUTZMDF(config-if)#mls ?
FLLUTZMDF(config-if)#do sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(52)SG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 12-May-09 19:13 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x124CAD60
ROM: 12.2(44r)SG5
Darkside Revision 4, Jawa Revision 18, Tatooine Revision 140, Forerunner Revision 1.74
FLLUTZMDF uptime is 2 days, 50 minutes
System image file is "bootflash:cat4500e-ipbasek9-mz.122-52.SG.bin"
FLLUTZMDF(config-if)#do show run int gig3/2
Building configuration...
Current configuration : 97 bytes
interface GigabitEthernet3/2
description Link to CUBE router
switchport access vlan 333
end
Matthew Blanshard
Looks like you are using a supervisor 6.  QOS is totally different on that supervisor, where it trusts automatically. Here's the config guide for qos on the sup6e:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/qos.html#wp1474085
-Matt
