4506E
nshoe18
Level 5
Level 5
We are replacing a 2811 router that is doing only internal routing with a 4506E and Sup V. I am trying to match the router config but I cannot create sub-interfaces. Is this possible with the 4506?
Edison Ortiz
Router config:
interface fx/x.100
encapsulation dot1q 100
ip add 192.168.100.x 255.255.255.0
interface fx/x.200
encapsulation dot1q 200
ip add 192.168.200.x 255.255.255.0
Moving that configuration to a switch
(create Layer2 Vlans)
config#vlan 100
config#vlan 200
(create Layer3 interfaces)
config#interface vlan 100
config#ip add 192.168.100.x 255.255.255.0
config#interface vlan 200
config#ip add 192.168.200.x 255.255.255.0
(interface carrying multiple Vlans)
config#interface fx/x
config#switchport trunk encapsulation dot1q
config#switchport mode trunk
(interface carrying a single Vlan)
config#switchport access vlan 100
config#switchport mode access
HTH,
__
Edison.
