4507 reloading mystery
scottwilliamson
Level 2
Level 2
Hi All,
One of our 4507Rs is periodically reloading but it does not give any clue as to why, for example there are no chrashdump files and the sh ver output states that the reason was down to a reload. We've tried upgrading the firmware to no avail (our other 4507s are running the same code with no problems).
Anyone else out there experienced the same thing and then got a solution?
Many Thanks,
Scott
smothuku
Level 7
Level 7
Hi Scott ,
how many slots are filled on 4507R switches and what modules are instlled on the switch.
If possible send us show tech of the switch.
Satish
Hi Satish,
here is the show tech output - I've removed the running config just in case.
Scott
evsrajatgupta
Hi scottwilliamson,
I think a syslog and monitoring tool lke mrtg or prtg. will help yo in finding the cause.
Please rate if helpful.
