4507 SSO mode Sup7L-E 10GbE interfaces
Brendan Marmont
What is the case with redundant Sup engine 10GbE interfaces. We can only get one in active state, the other interface stays inactive? Can we have all four interfaces active sharing the backplane?
Mod Ports Card Type                              Model
3     6      Sup 7L-E 10GE (SFP+), 1000BaseX (SFP)  WS-X45-SUP7L-E
4     6      Sup 7L-E 10GE (SFP+), 1000BaseX (SFP)  WS-X45-SUP7L-E
Mod  Redundancy role     Operating mode      Redundancy status
3   Active Supervisor              SSO                 Active
4   Standby Supervisor           SSO                 Standby hot
Arumugam Muthaiah
Hi Brendan,
The Supervisor Engine 7L-E has four uplink ports. Ports 1 and 2 support either 10GBASE SFP+ transceivers or 1000BASE SFP transceivers. Ports 3 and 4 support only 1000BASE SFP transceivers. There are restrictions on the use of the uplink ports in both single supervisor engine and redundant supervisor engine configurations and both 10-G and 1-G operation.
Refer the below Table for a matrix of uplink port permissible transceiver configurations and transceiver restrictions.
Table 3 Uplink Port SFP+ and SFP Transceiver Configurations
Port 1
Port 2
Port 3
Port 4
Single Supervisor Engine Configuration. 10-Gigabit Operation Selected Through CLI
SFP+
SFP+
Not usable
Not usable
Maximum bandwidth is 20 Gbps. SFP+ transceivers are installed in ports 1 and 2. Port 3 and port 4 are not usable.
SFP+
SFP
Not usable
Not usable
Maximum bandwidth is 11 Gbps. With SFP and SFP+ transceivers installed in ports 1 and 2, port 3 and port 4 are not usable. 10-Gigabit operation selected through CLI.
SFP
SFP+
Not usable
Not usable
SFP
SFP
Not usable
Not usable
Maximum bandwidth is 2 Gbps. With SFP transceivers installed in ports 1 and 2, port 3 and port 4 are not usable. 10-Gigabit operation selected through CLI.
Single Supervisor Engine Configuration. 1-Gigabit Operation Selected Through CLI
SFP
SFP
SFP
SFP
Maximum bandwidth is 4 Gbps. Any combination of SFP transceiver type can be used. SFP+ transceivers can not be used in this configuration.
Redundant Supervisor Engine Configurations. 10-Gigabit Operation Selected Through CLI
AS1—SFP+
SS2—SFP+
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
Maximum bandwidth is 20 Gbps. If you plan to populate two uplink ports with SFP+ transceivers, you must install one SFP+ transceiver in the active supervisor engine (port 1) and one SFP+ transceiver in the standby supervisor engine (port 1).
AS—SFP+
SS—SFP
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
Maximum bandwidth is 11 Gbps. If you plan to populate only two uplink ports with one SFP+ transceiver and one SFP transceiver, you can install one SFP+ transceiver in the active supervisor engine (port 1) and one SFP transceiver in the standby supervisor engine (port 1).
AS—SFP
SS—SFP+
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
Maximum bandwidth is 11 Gbps. If you plan to populate only two uplink ports with one SFP+ transceiver and one SFP transceiver, you can install one SFP transceiver in the active supervisor engine (port 1) and one SFP+ transceiver in the standby supervisor engine (port 1).
AS—SFP
SS—SFP
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
Maximum bandwidth is 2 Gbps. If you plan to populate only two uplink ports with SFP transceivers, you must install an SFP transceiver in the active supervisor engine (port 1) and one SFP transceiver in the standby supervisor engine (port 1)
AS = Active supervisor engine.
SS = Standby supervisor engine.
Refer:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_25750.html#wp29752
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Arumugam Muthaiah
Hi Brendan,
Port 1
Port 2
Port 3
Port 4
SFP+
SFP+
Not usable
Not usable
SFP+
SFP
Not usable
Not usable
SFP
SFP+
Not usable
Not usable
SFP
SFP
Not usable
Not usable
SFP
SFP
SFP
SFP
AS1—SFP+
SS2—SFP+
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—SFP+
SS—SFP
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—SFP
SS—SFP+
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—SFP
SS—SFP
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
AS—Not usable
SS—Not usable
Refer:
Aru
