4507 -SUP7 E Netflow
Vlad Olteanu
Level 2
Level 2
Guys,
I have just bought this Sup , but I ma not really familiar with it , so until I aquaintance myself I have a question.
I want to play with netflow, but I have an ipbase license and it seems its not available.
Is that the reason? Do I need another license?
Vlad
9 Replies 9
Latchum Naidu
From : http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/nfswitch.html
...Supervisor Engine 6-E and Catalyst 4900M chassis does not support Netflow.
To use the NetFlow feature, you must have the Supervisor Engine V-10GE (the functionality is embedded in the supervisor engine), or the NetFlow Services Card (WS-F4531) and either a Supervisor Engine IV or a Supervisor Engine V.
OR you may need to insert a daughter card which enables netflow.
Please rate the helpfull posts.
Naidu.
     Sup-7E has built Flexible NetFlow for you. However, your chassis should be E series chassis. Typo?
HTH,
Toshi
I do have an E Series chassis , but it seems I have only ip flow monitor option under interface command.
    Its not the same as you do on the router. It has many steps to do so.
Check this link out : http://www.cisco.com/en/US/docs/ios/fnetflow/configuration/guide/get_start_cfg_fnflow_ps6441_TSD_Products_Configuration_Guide_Chapter.html
HTH,
Toshi
Now it's more confusing.It says I should run IOS , but I am running IOS XE. Should I change the image?
This is my image:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-        UNIVERSALK9-M), Version 03.02.01.SG RELEASE SOFTWARE (fc4)
PS:When I tried putting a normal 12.x IOS , it said: "incompatible"
Vlad
     All right my fault. IOS-XE should be fine.
Try this link : http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/01xo/configuration/guide/fnf.html
HTH,
Toshi
Thanks so much!
I think this will do it now.
Vlad
you can check here(cisco feature navigator)  which IOS has the Netflow on the Sup 7E. It should be inbuilt on the Sup itself.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Kishore
