NAT Traslation in vlan interface
tdanetsco
I have a cisco router 3845 with Etherswitch modules and one Vlan configured "172.16.6/24", many switch ports are assigned to this vlan. i would like to translate one IP address 172.16.6.200 to a new one "172.25.42.10" but need to keep the other IPs from "172.16.6/24" without changes. below is the configuration of vlan interface and switch port, could someone help.
Best Regards,
Mustapha Bensalah.
interface Vlan100
description L3 Vlan interface for core_vlan
ip address 172.16.6.2 255.255.255.0
no ip redirects
no ip route-cache cef
no ip route-cache
standby 1 ip 172.16.6.1
standby 1 priority 250
standby 1 preempt
standby 1 authentication md5 key-string 7 052A32226E03012D3A2B1F01191C
end
interface FastEthernet4/35
description to RSG
switchport access vlan 100
no cdp enable
spanning-tree portfast
end
8 Replies 8
    Where is 172.25.42.10?  Please give us a bit more about your question.
Toshi
Hi Mustapha,
If you are sure that the network "172.25.42.10" (172.25.42.0/24) is reachable and have a route then you can do a NAT like below.
ip nat inside source static 172.16.6.200 172.25.42.10 extendable
As said above make sure that the network 172.25.42.0/24 is reachable.
Please rate the helpfull posts.
Naidu.
i would like to translate the source IP 172.16.6.200 to 172.25.42.10 only when i have to reach some specific IPs otherwise i don't want to translate the source IP, i want to keep it as it is. something like :
if destination IP is X.X.X.X then translate 172.16.6.200 to 172.25.42.10
else "do not make translation"
Best Regards,
Mustapha.
Hi Hi Mustapha,
Try like below and see...
Naidu.
       You can try this for testing.
access-list 101 permit ip host 172.16.6.200 host x.x.x.x
ip nat pool MYPOOL 172.25.42.10 172.25.42.10 mask 255.255.255.0
ip nat inside source list 101 pool MYPOOL
HTH,
Toshi
and what should be configured on ingoing and outgoing interfaces ?
BR,
mustapha.
De : thotsaphon
À : tdanetsco
Envoyé le : Mardi 22 Novembre 2011 9h27
Objet : - Re: NAT Traslation in vlan interface
Home
Re: NAT Traslation in vlan interface created by thotsaphon in LAN, Switching and Routing - View the full discussion
HTH,
Toshi
Reply to this message by going to Home
Start a new discussion in LAN, Switching and Routing at Home
On the incoming interface configure like below.
interface inside (fa0/1)
ip nat inside
On the outgoing interface configure like below.
interface outside (fa0/0)
ip nat outside
Naidu.
   Please provide a brief diagram. You need to route 172.25.42.10 back to that router.
Toshi
