4507 Switch module compatibility
neilrmessick
Level 2
Level 2
I am trying to add a WS-X4648-RJ45V-E line card. Its comming up saying...
_CHASSIS-3-UNKNOWNLINECARD: Unknown module (Field Replaceable Unit minor type 36
7) in slot 7
looking online, it apperas that it should work. Any idea whats up? Running IOS15.0(2)SG7
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4507R 7 slot switch "
PID: WS-C4507R         , VID: V06  , SN: FOX102001MR
NAME: "Clock Module", DESCR: "Clock Module"
PID: WS-X4K-CLOCK      , VID:      , SN: JAE10191N8H
NAME: "Mux Buffer 3 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590          , VID:      , SN: JAE10202NYW
NAME: "Mux Buffer 4 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590          , VID:      , SN: JAE10202NZ0
NAME: "Mux Buffer 5 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590          , VID:      , SN: JAE102138QX
NAME: "Mux Buffer 6 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590          , VID:      , SN: JAE102139KZ
NAME: "Mux Buffer 7 ", DESCR: "Mux Buffers for Redundancy Logic"
PID: WS-X4590          , VID:      , SN: JAE10212VRN
NAME: "Linecard(slot 1)", DESCR: "Supervisor V-10GE with 2 10GE X2 ports, and 4
1000BaseX SFP ports"
PID: WS-X4516-10GE     , VID: V07  , SN: JAE1116DU90
NAME: "TenGigabitEthernet1/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V02  , SN: FNS11140SJW
NAME: "Linecard(slot 2)", DESCR: "Supervisor V-10GE with 2 10GE X2 ports, and 4
PID: WS-X4516-10GE     , VID: V03  , SN: JAB1001002Z
NAME: "TenGigabitEthernet2/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V02  , SN: FNS11140SK5
NAME: "Linecard(slot 3)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 ba
seT ports"
PID: WS-X4548-GB-RJ45  , VID: V03  , SN: JAE10244CEK
NAME: "Linecard(slot 4)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 ba
seT ports"
PID: WS-X4548-GB-RJ45  , VID: V03  , SN: JAE10244CEQ
NAME: "Linecard(slot 5)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 ba
seT ports"
PID: WS-X4548-GB-RJ45  , VID: V03  , SN: JAE10244BTG
NAME: "Linecard(slot 6)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 ba
seT ports"
PID: WS-X4548-GB-RJ45  , VID: V03  , SN: JAE10244CDW
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4597          , VID: V06  , SN: NWG101801N5
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 1300W )"
PID: PWR-C45-1300ACV   , VID:      , SN: SON07060AC2
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 1300W )"
PID: PWR-C45-1300ACV   , VID:      , SN: SON07180A19
Leo Laohoo
See the "E" at the end of the part number?  It means that you need a "-E" chassis.
whats the proper part number for the POE blade? With all the variations of these chassis its really hard to turn up the right stuff on a google search.
Neil
Go to this link:-
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea_ps4324_Products_Data_Sheet.html
Go down to the section
Cisco Catalyst 4500 Classic Line Cards
Cards to suit your set up are here
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
glen.grant
  You are correct if you are to believe the release notes for 15.02 .  Says it's supported on a non E chassis as long as it's 12.2.40 .  This was under non E chassis supported hardware.  Wonder if it's faulty ?  Also you only have 1300 watt supplies  might want to check to see if you have adequate power for the poe card.
WS-X4648-RJ45V-E
48 port 10/100/1000 Mb with 2 to 1 oversubscription
12.2(40)SG
