01-25-2017 10:05 PM - edited 03-08-2019 09:04 AM
The port on sup 8 in cisco 4507 switch can be used to connect access switch? The port will be configured as a trunk port.
BR
Abdul Karim
01-26-2017 12:32 AM
hi as per the doc yes you should be able to
Up to eight nonblocking 10 Gigabit Ethernet uplinks (Small Form-Factor Pluggable Plus [SFP+])
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/data_sheet_c78-728191.html
01-26-2017 05:59 AM
As far as I know, that should work fine.
Personally, I haven't yet used a sup8 port as a trunk. If have used them as L3 ports with and without Etherchannel.
