01-19-2010 02:54 PM - edited 03-06-2019 09:21 AM
I am trying to configure a layer 3 uplink from a 4510E with a Sup 6E acting as an access layer switch to a 6513 Sup 720 distribution switch. I have tried enabling IP routing but I am still not able to assign IP addresses to any Ethernet interfaces on the 4510. If any one has any ideas I would appricate the help.
Mike
Config Follows:
version 12.2
no service pad
service compress-config
hostname ma100sr01
boot-start-marker
boot system flash bootflash:cat4500e-entservicesk9-mz.122-53.SG1.bin
boot-end-marker
no aaa new-model
hw-module module 5 port-group 2 select gigabitethernet
ip subnet-zero
ip vrf mgmtVrf
vtp domain AWC-Math
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode rapid-pvst
redundancy
mode sso
vlan internal allocation policy ascending
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
All Gi default
interface GigabitEthernet1/48
switchport mode trunk
shutdown
interface TenGigabitEthernet5/1
interface TenGigabitEthernet5/2
interface GigabitEthernet5/3
interface GigabitEthernet5/4
interface GigabitEthernet5/5
interface GigabitEthernet5/6
interface Vlan1
ip address 10.201.208.200 255.255.0.0
router eigrp 500
no auto-summary
eigrp stub connected summary
network 10.0.0.0
ip route 0.0.0.0 0.0.0.0 10.201.0.3
ip http server
no ip http secure-server
line con 0
stopbits 1
line vty 0 4
login
end
Solved! Go to Solution.
01-19-2010 02:56 PM
Mike
Config Follows:
version 12.2
no service pad
hostname ma100sr01
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
vtp domain AWC-Math
redundancy
mode sso
no ip address
speed auto
duplex auto
!All Gi default
shutdown
interface Vlan1
router eigrp 500
no auto-summary
network 10.0.0.0
ip http server
line con 0
stopbits 1
line vty 0 4
login
end
Have you configured "no switchport" under the interface before trying to apply an IP address ?
Jon
01-19-2010 02:56 PM
Mike
Config Follows:
version 12.2
no service pad
hostname ma100sr01
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
vtp domain AWC-Math
redundancy
mode sso
no ip address
speed auto
duplex auto
!All Gi default
shutdown
interface Vlan1
router eigrp 500
no auto-summary
network 10.0.0.0
ip http server
line con 0
stopbits 1
line vty 0 4
login
end
Jon
01-19-2010 03:03 PM
That seemed to be the answer. I have been spending way more time on the 6500 which defaults to a routed interface.
Mike
01-19-2010 03:10 PM
Mike
Mike
No problem, glad to have helped.
Jon
