06-02-2011 10:08 AM - edited 03-06-2019 05:18 PM
We have some 4510R+E with dual sup 7e that have experienced problems recently. One of the sup 7e's crashed with a "critical software exception":
#show ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.01.01.SG RELEASE SOFTWARE (fc1)
<snip>
ROM: 15.0(1r)SG1
<snip>
Last reload reason: Critical software exception, check bootflash:crashinfo_iosd
So I thought I'd upgrade to IOS-XE 3.2.0SG to hopefully resolve the issue. I was reading the software release notes and it says:
And from the ROMMON release notes it says:
So I have several questions:
The IP Base image does not support enhanced routing features such as Nonstop Forwarding (NSF) , BGP, Enhanced Interior Gateway Routing Protocol (EIGRP), Open Shortest Path First (OSPF), Intermediate System-to-Intermediate System (IS-IS), Virtual Routing Forwarding (VRF-lite) and policy-based routing (PBR).
Thanks!
11-25-2011 05:13 AM
Do you solve your 3 issues?
I will make the same upgrade process the next Monday and would like to know if the procedure worked for you.
