UDP traffic Priority over TCP
dparmar89
How can i ensure that UDP traffic has priotity over TCP data in a network?
cadet alain
You must implement QoS in your network.
On cisco routers this is done using MQC syntax like this:
class-map UDP_TRAFFIC
match protocol udp
class-map TCP_TRAFFIC
match protocol tcp
policy-map TRAFFIC_POLICY
class UDP_TRAFFIC
set dscp af31
class TCP_TRAFFIC
set dscp af21
int x/x
service-policy inbound TRAFFIC_POLICY
this will give priority to UDP vs TCP vs all other traffic except control plane traffic which has a higher DSCP value set
Regards.
Alain.
acampbell
You would need to use something like policmaps(QOS)
You will need to adjust interfaces access-list numbers etc to suit your set up
ip access-list 101
permit udp any any
ip access-list 102
permit tcp any any
class-map match-all UDP
match access-group 101
class-map match-all TCP
match access-group 102
policy-map UDP-THEN-TCP
class UDP
    priority percent 30
class TCP
   bandwidth remaining percent 60
class class-default
   fair-queue
int fast 0/0
service-policy out UDP-THEN-TCP
Alex
Regards, Alex. Please rate useful posts.
