45xx Switch blocking & non-blocking card required
Hi Expert,
Pls share the blocking & non-Blocking card of 45xx family
Also suggest if the below understanding / info is correct or not for 45xx Qos
45xx egress queue:  1p7q1t+DBL
ingress queue:       Trust Model based
Pls suggest
Br/Subhojit
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As a simplicafication, if a port doesn't have full bandwidth to the fabric, it's considered blocking.  In the 4500 line cards, there's a least one (4418-GB) where some ports on the card are non-blocking while the others are blocking.  Datasheet for 4500 line cards: http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea_ps4324_Products_Data_Sheet.html
Yes and no.  It depends on the installed supervisor.  The older supervisors normally support only 4 queues (e.g. sup V), and they don't trust by default.  The newer supervisors (e.g. sup 7) have, I believe, what you describe.
Don't forget Sup8, Joe.
Laugh - I didn't.  Sup 7 was an example of a "newer" 4500 supervisor.  Sup 8 is "newer" still.
