4900m Management Access
jjackson
We have two 4900m Catalyst Switches with IOS Software Version 12.2(53) SG8. New to initally configuring a Cisco managed switch. Need help or step-by-step instructions on setting up management so I can access switches by web browser or embedded CiscoView.
paolo bevilacqua
Wrong forum, post in "LAN and switching". You can move your posting using the Actions panel on the right.
jawad-mukhtar
Level 4
Level 4
1) configure an IP address on the management port
Switch>en
Switch#configure terminal
Switch(config-if)#interface FastEthernet1
Switch(config-if)#ip vrf forwarding mgmtVrf
Switch(config-if)#ip address 192.168.0.240 255.255.255.0
Switch(config-if)#speed auto
Switch(config-if)#duplex auto
Switch(config-if)#exit
Switch(config)#exit
Switch#
2) ping to check if it works
Switch#ping vrf mgmtVrf 192.168.0.127
Sending 5, 100-byte ICMP Echos to 192.168.0.127, timeout is 2 seconds: !!!!!
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Switch#
3) configure the management port as source for the TFTP
Switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#ip tftp source-interface FastEthernet1
Switch#exit
Switch#
4) copy the IOS
Switch#copy tftp: slot0:
Address or name of remote host [192.168.0.127]?
Source filename [XYZ]?
Destination filename [XYZ]?
Accessing tftp://192.168.0.127/XYZ
it should load now......
***Do Rate All Helpful Posts***
Jawad
Jawad
Hi Jawad,
Thank you for you help. In step #4 I'm getting "%Error opening tftp://
/ciscoview.tar (Timed out). What should
be. . .fa1 IP Address? In Step #1 you have 192.168.0.240 as the IP for fa1 and in Step #2 you are pinging 192.168.0.127 and using it in Step #4. Should the two IP address in your examples be the same or meant to be different?
Thank you,
John
