4948 or 4948E based on Show outputs
Hi Guys,
I have 4948 switch but i am unaable to determine its 4948E or Just 4948 as there is some confusion between BOQ and actual delivered material. In Boq its mentioned 4948E but as per switch show commands output its looks like just 4948.
I need to run EVN features on it but it supports only on 4948E and 4900M switch but not on just 4948
please look at the below show outputs.
In addition is this image is fine to support EVN feature as Cisco feature tool is still not update for 4500 switch.
Switch#sh module
Chassis Type : WS-C4948
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1    48  1000BaseX (SFP) Supervisor             WS-C4948           FOX1419G0B6
M MAC addresses                    Hw  Fw           Sw               Status
1 c471.fe68.9c00 to c471.fe68.9c2f 1.8 12.2(31r)SGA 15.0(2)SG4       Ok
System Failures:
Power Supply:   bad/off (see 'show power')
Switch#sh inven
Switch#sh inventory
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4948 1 slot switch "
PID:                   , VID:      , SN: FOX1419G0B6
NAME: "Linecard(slot 1)", DESCR: "10/100/1000BaseT (RJ45), 1000BaseX (SFP) Supervisor with 48 10/100/1000BASE-T ports and 4 1000BASE-"
PID: WS-C4948          , VID: V09  , SN: FOX1419G0B6
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 300W )"
PID: PWR-C49-300AC     , VID:      , SN: QCS1443B1XR
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 300W )"
PID: PWR-C49-300AC     , VID:      , SN: QCS1443B1X5
Switch#sh ver
Switch#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Version 15.0(2)SG4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 19-Mar-12 15:31 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x121AB880
ROM: 12.2(31r)SGA2
Dagobah Revision 226, Swamp Revision 5
Switch uptime is 3 hours, 13 minutes
System returned to ROM by reload
System image file is "bootflash:cat4500-entservices-mz.150-2.SG4.bin"
cisco WS-C4948 (MPC8245) processor (revision 0) with 262144K bytes of memory.
Processor board ID FOX1419G0B6
MPC8245 CPU at 266Mhz, Fixed Module
Last reset from Reload
1 Virtual Ethernet interface
48 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Switch#sh idprom supervisor
Supervisor 1 Idprom :
Common Block Signature = 0xabab
Common Block Version = 1
Common Block Length = 144
Common Block Checksum = 3008
Idprom Size = 256
Block Count = 4
FRU Major Type = 0x4101
FRU Minor Type = 356
OEM String = Cisco
Product Number = WS-C4948
Serial Number = FOX1419G0B6
Part Number = 73-9130-12
Part Revision = A0
Manufacturing Deviation String = 0
Hardware Revision = 1.8
Manufacturing Bits = 0x0000
Engineering Bits = 0x0000
Snmp OID = 0.0.0.0.0.0.0.0
Power Consumption = 0
RMA Failure Code = 0 0 0 0
Supervisor Block Signature = 0x4101
Supervisor Block Version = 1
Supervisor Block Length = 24
Supervisor Block Checksum = 1091
Feature Bits = 0x0000000000000000
Card Feature Index = 113
MAC Base = c471.fe68.9c00
MAC Count = 64
Clei Block Signature = 0x4601
Clei Block Version = 1
Clei Block Length = 22
Clei Block Checksum = 952
Clei code string = COM2P10ARF
Version ID string = V09
SecSerialNum Block Signature = 0x4602
SecSerialNum Block Version = 1
SecSerialNum Block Length = 26
SecSerialNum Block Checksum = 791
SecSerialNum string = JAE14520EJY
Switch#
Fazal
Reza Sharifi
Have a look at table-1 in this link
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/product_bulletin_c25-552113.html
amikat
Judging from the outputs posted my view is that your box is NOT Cat4948E switch. For that type the switch should be identified as WS-C4948E model. In the "sh ver" output you should see WS-4948E (MPC8548) ... Also the PSU units for the 4948E type are identified as PWR-C49E-300AC-R. Also the IOS file at your version should read cat4500e-entservices-mz.150-2.SG4.bin for the 4948E unit and the minimum ROMMON release should be  12.2(44r)SG8 while your is 12.2(31r)SGA2.
Finally I do hope you are referring to WS-4948E box and NOT WS-4948-E which would be a different story.
Best regards,
Antonin
