Track IP routes on 6509
aweise
We have a need to track specifc subnets on our two 6509s, running IOS version 12.2(18)SXF16. Basically, we want to do this:
track 1 192.168.0.0 255.255.255.252 reachability
track 2 192.168.1.0 255.255.255.252 reachability
However, the 6509 IOS only provides the option to track an interface. Is this a feature that's available in later IOS versions?
Is there another way to track these routes? The subnets are used for WAN links at a HQ and DR site and we are doing a specific PBR (sending all http/https traffic) using these subnets. If that WAN link goes down, we want to be able to utilize a backup WAN link to support that traffic.
siddhartham
Level 4
Level 4
You can use IP SLA to achieve your goal
ip sla 1
icmp-echo X.X.X.X   ( IP address of ISP-1)
timeout 50    -- Time in msec to complete the IP SLA operation
frequency 3  --- number of pings it will send
ip sla schedule 1 start-time now life forever
track 1 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 Y.Y.Y.Y track 1
ip route 0.0.0.0 0.0.0.0 Z.Z.Z.Z 100
This will ping x.x.x.x and if it looses 3 pings then it will delete ip route 0.0.0.0 0.0.0.0 Y.Y.Y.Y from routing table and adds the following route ip route 0.0.0.0 0.0.0.0 Z.Z.Z.Z 100
Siddhartha
Siddhartha
Unfortunately, ip sla isn't even an option in our IOS:
SWITCH(config)#ip ?
Global IP configuration subcommands:
[options removed]
  sap                     Global IP Multicast SAP Commands
  scp                     Scp commands
  security                Specify system wide security information
  slb                     Server Load Balancing
  source                  IP source
  source-route            Process packets with source routing header options
  ssh                     Configure ssh options
  sticky-arp              Allow the creation of sticky ARP entries
  subnet-zero             Allow 'subnet zero' subnets
This is why I asked the original question (sorry, I forgot to mention that). I would have used ip sla, but since it's not available, I wondered if there was another option. Seems like we're limited with our options.
Thanks!
