4948 Web UI??
nate faulds
Level 2
Level 2
So i have a 2960 switch that has the fancy web UI. It's the Catalyst 2960-S Series Device Manager to be specific.
I have the cat4500-entservicesk9-mz.150-2.SG11 image on the switch but it appears that it does not come with a web UI like the 2900 series? Is this correct or did the person i bought this from not include the web UI files?
Theres nothing else to download under the 4948 section unfortunately, only CNA or the software itself
These are not campus switches really like 2ks and 3k series that's probably why it was never made available
We used them in the DC as ISCI switches
6 Replies 6
Mark Malone
Here the link to the the network assistant
Select a Software Type
Cisco Network Assistant
IOS ROMMON Software
IOS Software
https://software.cisco.com/download/home/283027810/type
Georg Pauwen
in addition to Mark's post, I tried to find the commands 'ip http server' and 'ip http secure-server' in the command reference but they don't seem to be there. Can you check if you have those commands available in global config mode ?
ip http and ip http secure-server work fine and there is a web UI but it's the oldschool pointless UI.
I have network assistant but don't really use it(not that great tbh), i'd rather have the fancy web UI like the 2960S i have has on 15.0 so i can checkup on status info randomly and keep configuring via CLI. I have SNMP working fine but i want to know if the 4948 has the same web UI option as the 2960S and 3560S have. I've attached a screenshot of what im trying to describe.
I have mine in English not French though just fyi.
Bummer yeah i know they are meant for DC's but i figured they would provide some sort of web UI like the 2K and 3K series. No worries though this is more of a question about the web UI then how to get the 2K series web UI to show lol.
Thanks for the help guys.
