5506-X VLANs + DMZ configuration in Packet Tracer v8.0.0.0212
samellington
I am trying to create a network using the topology in the screenshot below.
My main obstacle at the moment are the 5506-X firewalls. I have VLANS set up on CambridgeRouter and HartfordRouter to separate the wireless and wired end devices on the switches. How do I set the firewalls up in such a way that they act as a passthrough for the vlans set up on the router?
The current configurations of the routers and switches are below.
CambridgeRouter:
En
Conf t
Hostname CambridgeRouter
Banner motd $ Unauthorized Access is Prohibited $
Enable secret Tooth2
Service password-encryption
Line con 0
Password CambridgeConsole
Logging synchronous
Login
Exec-timeout 6 45
Exit
Line vty 0 15
Password Tooth1
Logging synchronous
Login
Exec-timeout 6 45
Exit
Router rip
Version 2
Network 192.168.3.0
Network 192.168.4.0
No auto-summary
ip dhcp excluded-address 192.168.3.1 192.168.3.15
ip dhcp excluded-address 192.168.4.1 192.168.4.15
ip dhcp pool vPool10
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server 4.4.4.4
exit
ip dhcp pool vPool20
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
dns-server 4.4.4.4
exit
Int g0/0
No ip address
No shut
Duplex full
speed 1000
int g0/0.10
encapsulation dot1q 10
ip address 192.168.3.1 255.255.255.0
exit
int g0/0.20
encapsulation dot1q 20
ip address 192.168.4.1 255.255.255.0
exit
int g0/1
shut
exit
Int g0/1/0
Shut
Exit
Do copy run start
CambridgeSwitch:
En
Conf t
Hostname CambridgeSwitch
Enable secret Tooth1
Line con 0
Logging synchronous
Login
Exec-timeout 6 45
exit
Line vty 0 15
Password Tooth1
Logging synchronous
Login
exit
vlan 10
name Wired
int vlan 10
ip address 192.168.3.5 255.255.255.0
vlan 20
name Wireless
int vlan 20
ip address 192.168.4.5 255.255.255.0
Int Vlan1
No shut
Ip address 192.168.3.2 255.255.255.0
Ip default-gateway 192.168.3.1
Interface range FastEthernet0/1-21
No shutdown
Switchport mode access
Switchport access vlan 10
Duplex full
Speed 100
Exit
Int f0/22
No shut
Switchport access vlan 20
Duplex full
Speed 100
Int range f0/23-24
Shut
Exit
Int g0/1
No shut
Switchport mode trunk
Duplex full
Speed 1000
Description Router 1
Exit
Int g0/2
Shut
Exit
Do copy run start
HartfordRouter:
En
Conf t
Hostname HartfordRouter
Line con 0
Password HartfordConsole
Logging synchronous
Login
Exec-timeout 6 45
Exit
Line vty 0 15
Password Tooth1
Logging synchronous
Login
Exec-timeout 6 45
exit
Router rip
Version 2
Network 192.168.0.0
Network 192.168.1.0
No auto-summary
ip dhcp excluded-address 192.168.0.1 192.168.0.15
ip dhcp excluded-address 192.168.1.1 192.168.1.15
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 4.4.4.4
exit
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 4.4.4.4
Int g0/0
No ip address
No shut
Duplex full
Speed 1000
Exit
Int g0/0.10
Encapsulation dot1q 10
Ip address 192.168.0.1 255.255.255.0
Exit
Int g0/0.20
Encapsulation dot1q 20
Ip address 192.168.1.1 255.255.255.0
Int g0/1
Shut
exit
exit
copy run start
exit
HartfordSwitch:
En
Conf t
Hostname HartfordSwitch
Line con 0
Logging synchronous
Login
Exec-timeout 6 45
exit
Line vty 0 15
Password Tooth1
Logging synchronous
Login
exit
vlan 10
name Wired
int vlan 10
ip address 192.168.0.5 255.255.255.0
vlan 20
name Wireless
int vlan 20
ip address 192.168.1.5 255.255.255.0
Int vlan1
No shut
Ip address 192.168.0.2 255.255.255.0
Ip default-gateway 192.168.0.1
Interface range FastEthernet0/1-9
No shutdown
Duplex full
Speed 100
Exit
Int f0/10
No shut
Duplex full
Speed 100
Int range f0/11-24
Shut
Exit
Int g0/1
No shut
Duplex full
Speed 1000
Exit
Int g0/2
shut
exit
exit
copy run start
exit
0 Replies 0
