5K Port-Channel Issue: command failed: port not compatible [DCE mode]
Louis Gonzales
I'm getting the following error when I try to configure
my uplinks on my 5K back to my 7K's.
I'm currently running NX-OS: n5000-uk9.5.0.2.N1.1.bin
Any ideas would be helpful.
interface port-channel10
  switchport mode trunk
  vpc 10
  switchport access vlan 5
  switchport trunk native vlan 2005
  switchport trunk allowed vlan 5,7
  speed 10000
interface Ethernet1/33
  spanning-tree port type network
  udld aggressive
channel-group 10 mode passive
There is a bug for this issue which is fixed in 5.0(2)N2(1) which is on CCO. Here is the bug details
CSCtk04010 Port errors when adding to port-channel port not compatible [DCE mode]
Symptom:
Cannot add port to port channel.
Error:
Conditions:
adding ports to port channel
Workaround:
remove and re-add the port channel config
Upgrading or re-adding the config should work
Kind regards,
Maarten Vervoorn
Symptom:
Error:
Conditions:
Workaround:
Kind regards,
Maarten Vervoorn
