04-08-2014 10:56 AM - edited 03-07-2019 07:01 PM
I need to boot my 6500 from external flash, and I put the command "boot system flash s72033-adventerprisek9_wan-mz.122-33.SXI13.bin" to set the boot variable. But still the switch is booting from flash sup-bootdisk: and also the boot variable is set to flash sup-bootdisk: . Can any one please tell me how to solve this issue
this is the show run
boot-start-marker
boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH4.bin
boot-end-marker
and
Router#sho bootvar
BOOT variable = sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH4.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
04-08-2014 12:14 PM
Hello
i would suggest to change the boot variable to contain both old and new iOS but have the new iOS try to boot first
Conf t
no boot system
r
boot system flash:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin
Sh boot
wr
res
paul
04-08-2014 01:06 PM
Conf t
No boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH4.bin
boot system flash xxxxx:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin
boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH4.bin [Backup OS]
Exit
Copy run start
04-08-2014 03:37 PM
External flash? Like the CF?
It is known as "disk0:". So your boot variable is "boot system flash disk0:IOS_filename.bin".
04-09-2014 04:40 AM
it will be showing disk 0: while copying but there no disk0 for the bootsystem command. Thank you for reply
04-09-2014 03:22 PM
Ok, if the command "boot system flash disk0:" not allowed, can you please post the output to the command "dir disk0:" and the output to the command when you enter in configuration mode?
All my Sup720 have "disk0:" as a secondary boot variable.
04-09-2014 04:45 AM
I tried all of the above .... but it was not working, Then I copied the ios from flash to sup-bootflash. Now the ios is new one in sho version command, but still there is no change in sho bootvar command. Any way I have managed to boot the new IOS, Thank you all for your reply
