06-10-2008 12:38 PM - edited 03-05-2019 11:32 PM
Will the conversion utility migrate the CatOS running-config (what vlan a port is on) to Native IOS? From the below link I understand the answer is 'no', it just upgrade it and I get no config.
How to Convert a Catalyst 6500/6000 Supervisor Engine from Hybrid Mode (CatOS) to Native Mode (IOS) Using a Conversion Utility
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008070f124.shtml
b. BuildingA 6506 CatOS 8.4(5)
1. Mod 1 WS-X6K-SUP2-2GE 128MB DRAM 128MB FlashCard bootflash:cat6000-sup2cvk9.8-4-5.bin
2. Mod 3 WS-X6148-RJ45V
3. Mod 4 WS-X6148-RJ45
c. Building B 6513 CatOS 7.6(4)
1. Mod 1 WS-X6K-SUP2-2GE standby
2. Mod 2 WS-X6K-SUP2-2GE active 256MB FlashCard bootflash:cat6000-sup2cvk8.7-6-4.bin
3. Mod 3 WS-X6348-RJ-45
4. Mod 4 WS-X6624-FXS
5. Mod 5 WS-X6148-GE-TX
6. Mod 6 WS-X6348-RJ-45 (PoE)
7. Mod 7 WS-X6348-RJ-45 (PoE)
8. Mod 8 WS-X6348-RJ-45 (PoE)
9. Mod 9 WS-X6348-RJ-45 (PoE)
10. Mod 10 WS-X6348-RJ-45 (PoE)
11. Mod 11 WS-X6348-RJ-45 (PoE)
12. Mod 12 WS-X6348-RJ-45 (PoE)
13. Mod 13 WS-X6348-RJ-45 (PoE)
14. Mod 15 MSFC2 (other)
15. MOd 16 <nothing>
06-16-2008 01:07 PM
Follow the URL for the Conversion from CatOS to Cisco IOS for Catalyst 6500/6000 Switches.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
06-16-2008 01:43 PM
No it won't. Look at the router> prompt displayed in the doc. It just converts the Sup from Hybrid to Native IOS. This is something you can do manually much easier.
Also, it does this LIVE. Nothing off-line for this conversion.
Also don't bother with the CatOS to IOS converter. It also is about worthless. TAC advised me not to use it. I did some tests, it took my 30,000 line CATOS config and made it almost 70,000 lines.
Using "interface range" and tftp of the MFC config is the best way to do it.
Don't forget you can tftp just "interface's". TFTP will "add" to the config, not over-write it. Example, I tftp my MFC L3 info up to the switch.
Next I tftp up a "interface config" file that setup ports gi0/1-48 on Vlan3 with descriptions.
Make sure you end your text file with end.
Sho cdp neigh and sho cdp neigh det is a big help. you need to know what is trunking off the catos and what native Vlan is being used.
