6500 port-channel question
sfalbe
I am port-channeling between 2 6500 switch with Sup720's running IOS with the following code: s72033-jk9sv-mz.122-18.SXD7
The original configuration, is listed below.
Int port-channel 1
No ip address
Logging event link-status
Logging event bundle-status
Logging event trunk-status
Switchport
Switchport encapsulation dot1q
Switchport native vlan 2
Switchport trunk
I wanted to remove a VLAN from the trunk using the following command.
switchport trunk allow vlan remove 206
when I typed in the command, the port-channel, the went down, and remained down until I typed in the command on the second switch.
Po1 went down, on the first switch,
Po1A came up on the first switch
Po1 went down on the second switch, Po1B came up on the second switch.
Is there something I can do to prevent this from happening in the future?
Steve
ruesch-eng
Unfortunately, no. The range of allowed vlans must be the same on both sides.
glen.grant
It operated normally all parameters must match on both sides for the channel to work . You get a short period to get it in on both sides but then the channel will go down if they don't match . Best thing to do in cases like that is to telnet into both switches and get into the int port channels and make your changes to both sides as close as possible timewise . it should keep the port up. Haven't seen them referenced as PO1A and P01B what is that ? Anyone see that before ???
