6500 ROMMON requirment for vss
esther.pywong
I have one 6506-E in production network with s2t54-IPSERVICESK9-M), Version 15.0(1)SY3.
ROM: System Bootstrap, Version 12.2(50r)SYS2, RELEASE SOFTWARE (fc1).
And i am going to form vss with another new 6506-E. But the System Bootstrap is not in the same version.
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
So may I know if the ROMMON should be in the same version? Since I did not find any requirment about ROMMON in vss. Thanks!
Esther,
Rommon version will not cause any problem for the VSS migration.
Inayath
7 Replies 7
Ganesh Hariharan
Check out the below link on software /hardware pre-requsite for VSS configuration.
Pre-Requisite for VSS
Hope it Helps..
-GI
Rate if it Helps
Yes, Thanks.
But the problem is my IOS is in the same version. Only the ROMMON version is different.
And the hardware and software requirements of VSS do not talk about the ROMMON requirment.
So I am just want to make sure the different ROMMON version will not cause any problem of the VSS migration. Thanks.
Esther,
Inayath
Thanks, InayathUlla!!
Thanks for your link!
yasir shaikh
hi
Friend..
step 1
Go to romman Mode in VSS switch
step2
Clear virtual-switch         //disable vss mode///
Step3
Upload New IOS in all switches  using managment Port Through TFTP server
step4
Boot all switches using New IOS
step5
At last u configure VSS
step6
verify show version command
Thanks for the detail step for VSS.
