12-05-2007 09:05 PM - edited 03-05-2019 07:51 PM
Guys, apart from the bandwidth advantages, what are the other benefits one gains from upgrading from Sup2 to Sup720? I know there is CPU rate limiting. Does anybody have a link so that I can read about this.
If you list out other features too, I'll research them
Thank you
12-05-2007 11:32 PM
Well a few things spring to mind
1) In built connection to switch fabric on sup720 so you don't need a separate SFM which means you save a slot.
2) Ability to run 67xx modules which have more bandwidth to the switch fabric.
3) Sup720's have more future proofing.
4) More features are done on the PFC so better overall performance.
There are probably a lot more, the easiet thing to do is under Product & Services have a look at the data sheets for both the Sup2 and the Sup720.
Jon
12-06-2007 01:10 AM
The document you should read is: http://cisco.com/en/US/partner/products/hw/switches/ps708/products_white_paper0900aecd803e508c.shtml
Difference between Sup720 and Sup32 are Fabric, MSFC revision, and Switch Processor placement (in SUP720, SP and RP are on MSFC).
But otherwise, hardware forwarding is almost the same - this should give you an idea how much more powerful SUP720 is against SUP2 - it just forwards and does much much more in Hardware.
To list a few:
- Multicast
- RPF check
- VACL and VACL span port
- GRE hardware...
Just check out the table "Supervisor Engine 32 with PFC3B Layer 3 Features" in mentioned document.
PFC3B is same between Sup32 and Sup720, so hardware forwarding features are similar.
Hope this helps.
Please rate if it does
12-10-2007 04:36 PM
I've heard that there is this new feature in the sup720 that captures all traffic going through (not span) and helps with diagnostics. Can anybody shed some light?
