2501 stuck in cold start
wuh
Hi, all.
I have a 2501 router. Everytime, when it starts, it stops, saying snmp agent on host router is undergoing a cold start...
even when it wouldnt stop when i type break to go Rommon mode.
what might be the problem. I've copied the message here.
00:00:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to up
00:00:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed sta
te to down
00:00:20: %SYS-5-CONFIG_I: Configured from memory by console
00:00:23: %LINK-5-CHANGED: Interface Serial0, changed state to administratively
down
00:00:23: %LINK-5-CHANGED: Interface Serial1, changed state to administratively
down
00:00:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to down
00:00:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state
to down
00:01:04: %SYS-5-RESTART: System restarted --
IOS (tm) 2500 Software (C2500-IO-L), Version 12.2(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Sat 31-Jul-04 03:32 by eaarmas
00:01:04: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold star
tˇ
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
2500 processor with 16384 Kbytes of main memory
F3: 9286440+846656+770252 at 0x3000060
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Image text-base: 0x03050A44, data-base: 0x00001000
cisco 2500 (68030) processor (revision A) with 16384K/2048K bytes of memory.
Processor board ID 01207578, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Press RETURN to get started!
00:00:07: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
00:00:08: %LINK-3-UPDOWN: Interface Serial0, changed state to up
00:00:08: %LINK-3-UPDOWN: Interface Serial1, changed state to down
to up
te to down
00:00:21: %LINK-5-CHANGED: Interface Serial0, changed state to administratively
down
down
00:00:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to down
to down
tˇ
+++++++++++STOPS HERE, then i reboot it.
glen.grant
Are you saying that it starts rebooting over and over by itself ? Otherwise that is a normal end of boot message meaning it is ready to configure , just hit the enter key at that point.
No, it is rebooting over and over. it just freezes there. then after I reboot, it does the same thing.
Sorry, a typo. Please ignore the last message i added. it should be.
No, it is NOT rebooting over and over. it just freezes there. then after I reboot, it does the same thing.
thanks,
