02-22-2011 11:11 AM - edited 03-06-2019 03:41 PM
Hi All,
Looking for advice on a design. I'm upgrading my agin 4507R backbone to somthing more scalable.
I have been investigating 3 different designs, just looking for some feed back:
Requirments I have to work with:
· Total of 155 connected ports
o 55 of those are going to ESX hosts (15).
o 30-ish are devices that are simply for appliance management; SAN Switches, KVMs etc etc. These ports don’t even need Gig connectivity.
· I’ve been asked to bring in 10g to the environment
o Really, only our 15 ESX hosts right now would benefit from this.
o SAN is running FC, this was just replaced and new FC switches purchased.
· I have been tasked with implementing DMVPN this year.
· Need L3 capabilities. OSPF and BGP
· Need to maintain current 100/1g density for the time-being until we can migrate to 10g. currently at 96 10/100/1000 ports per 4500.
It’s a collapsed core design. WAN connects directly to 4500s and then access-layer switches from my various floors at HQ location connect directly to core along with servers. We don’t have any server aggregation switches currently. We’re about 90% virtual, so most things are consolidated onto 15 ESX hosts. WAN is MPLS with BGP Peering to provider via the 4500s.
I'm liking option 3 right now because it's more of a "Tierd" approach soft of, but i was wondering what others think. I'm not required to go with lowest cost, I've been able to go with what is RIGHT for us not necessarilly the cheapest. Any input would be appreciated.
02-22-2011 11:34 AM
I agree with you. Option 3 provides you with a tier approach and I also like it very much.
I hate connecting the WAN directly onto the Core.
Have you consider Option 3 with 3750s instead of N5Ks?
02-22-2011 11:39 AM
I have thought about the 3750s, but I want the 10g density offered by the Nexus line. I'd also like to do DCB (Maybe) with my DR location.
02-22-2011 11:42 AM
Option 3 it is
02-22-2011 01:00 PM
Any news on when SUP-1.4T will be out?
VSS-Sup2T will be out before the 3rd quarter of 2011, I am guessing. WS-X6708-10GE won't be supported due to the DFC/PFC. WS-X6704-10GE and WS-X6716-10GE will require a DFC/PFC upgrade.
Cons: 3945Es Might be a bottleneck.
What bandwidth do you have in mind? If you want a WAN bandwidth of >1Gb then the 3900 doesn't have enough "umph" to generate a grunt. Consider the ASR 1K with ESP5 (at least). That'll give you, around >4Gb bandwidth (half duplex, non-encrypted).02-22-2011 01:17 PM
Leo,
Good Point!
02-22-2011 01:47 PM
Thanks for the ratings Edison. Where have you been hiding lately?
02-22-2011 01:50 PM
Well deserved Leo - you should be rated more often.
Hiding? I stop by often but these forums are well covered so I don't answer much
02-22-2011 01:55 PM
02-22-2011 02:01 PM
Thanks to both of you. I was hoping some seasoned veterans such as yourself would weigh-in.
02-22-2011 02:05 PM
Seasoned veterans my foot! I'm a newbie. I just read some of the posts of the other "seasoned veterans".
02-22-2011 01:27 PM
True that. WAN is only 55mb right now, and we don't have any plans to go over 100mb. The only concerns I'd have are as far as LAN routing
on those guys, but really, the only HIGH bandwidth stuff that have is on it's own VLAN anyway and doesn't need to be routed.
02-22-2011 01:54 PM
The only concerns I'd have are as far as LAN routing on those guys, but really, the only HIGH bandwidth stuff that have is on it's own VLAN anyway and doesn't need to be routed.
Then the 3900 may be an overkill but I don't see any issues with the 3900 anyway.
02-23-2011 06:29 AM
55Mbps? 100Mbps Ethernet Handoff?
You need traffic-shaping.
If you elect the 6500, you need to purchase the SIP/SPA module for traffic-shaping.
If you elect the Nexus 7k, you can do traffic-shaping with the LAN ports. However, the 7K is targeted for Core/DC purposes, not at the WAN Layer.
If you elect the 3900, traffic-shaping is available.
I'm not sure how you are doing it now with the 4500 switch.
It sounds like option #3 is the best according to your budget and requirement.
02-23-2011 07:01 AM
Note also that the 7K won't take the low end 10/100 iLo and KVM type ports.
One downside with any of the Nexus solutions is the need to familiarize yourself with NX-OS features and syntax. Overall, I'd say the Nexus line hasn't taken off the way Cisco had hoped it would. (Thus the aggressive pricing many folks are seeing.) Also, we have seen an inordinate number of power problems with our 2248 FEX's.
I think they need to revamp that line a bit to make it a better fit for many enterprises.
