6500 VSS Active/Standby Issue
Tim Johnson
I have configured such that switch 1 always be the active role. Last night, Switch 1 lost power; Switch 2 became active, however, when power restored to Switch 1, it came up as Standby and did not transition to Active. Below are the details as configured on the switch:
switch virtual domain 100
switch mode virtual
switch 1 priority 200
switch 1 preempt
redundancy
main-cpu
auto-sync running-config
mode sso
However, a Show Switch virtual:
Switch mode : Virtual Switch
Virtual switch domain number : 100
Local switch number : 2
Local switch operational role: Virtual Switch Active
Peer switch number : 1
Peer switch operational role : Virtual Switch Standby
So - Why did Switch 1 Not assume the active Role? Is something missing in my config?
Tim
Hi Tim;
Eventhough you configure preempt, if you haven't did a copy-run-start it will disable the preempt command so that the active switch will not loose the running config. so try copying the running config to startup and it should work normally.
Make sure you always issue copy run start everytime you do some changes. For a preempt to work both the startup and running config should be same.
Hope to help;
Rams
5 Replies 5
uwe.kadner
can you please post
A) the part of the virtual switch config for switch 2
B) do a 'sh switch virtual role' on both of the switches?
C) the relevant lines from the logging buffer?
uk.
A) Not sure we are on the same page. Being a virtual switch - the config is synced between the switches. Switch 2 will have a copy of the running config from Switch 1. Once the stand-alone switches are converted to virtual, the only thing in the config is the following:
switch mode virtual
switch 1 preempt
Documentation states that priority 200 and preempt inform the switches to make switch 1 the active role after the default 15 minute standby preempt.
(B)sho switch virtual role
Switch Switch Status Preempt Priority Role Session ID
Number Oper(Conf) Oper(Conf) Local Remote
LOCAL 2 UP FALSE(N ) 100(100) ACTIVE 0 0
REMOTE 1 UP TRUE (Y*) 200(200) STANDBY 9483 416
Standby configured preempt timer(switch 1): 15 minutes
In dual-active recovery mode: No
Tim
Hi Tim;
Hope to help;
Rams
That's exactly what it was. I am in the habit of the older "write mem" and need to change to the "copy run start". Thanks for the quick responses everyone.
there shouldn't be any difference between wr mem and copy run start.
Both commands syncronise the startup config.
002877: Aug 15 14:07:09.138 CEST: %PFINIT-SW1_SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router.
it means your config was just not saved. and therefore there was no pre-empt.
