6504 vss pair shows Active/Active on led's but not in config
donald.james
After rebooting a pair of 6504's configured for vss, both switches show active on the sup modules. A show switch virtual redundancy however shows the pair working in an active/standby mode. We have 6509's in vss pairs and they show active on switch1 and standby on switch2 led's. For the 6504's switch 1 was booted first and then the second switch about 30 seconds later. Is there something different with the 6504's?
                 My Switch Id = 1
                Peer Switch Id = 2
        Last switchover reason = none
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
Switch 1 Slot 1 Processor Information :
        Current Software state = ACTIVE
       Uptime in current state = 20 hours, 42 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Mar-10 22:30 by prod_rel_team
                          BOOT = sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH7.bin,1;disk0:s72033-ipservicesk9_wan-mz.122-33.SXH7.bin,1;sup-bootdisk:,1;disk0:,1;
        Configuration register = 0x2102
                  Fabric State = ACTIVE
           Control Plane State = ACTIVE
Switch 2 Slot 1 Processor Information :
        Current Software state = STANDBY HOT (switchover target)
       Uptime in current state = 20 hours, 41 minutes
           Control Plane State = STANDBY
Thanks, Donald
Reza Sharifi
VSS is the same across all the 6500 models.
Can you post the ouput of
"sh switch virt role"?
Are you using fast hello for dual-active detection of ePAGP?
"sh swit virt dual"
#sh switch virt role
Switch  Switch Status  Preempt    Priority  Role     Session ID
        Number         Oper(Conf) Oper(Conf)         Local  Remote
LOCAL    1     UP      FALSE(N )   200(200)  ACTIVE   0      0
REMOTE   2     UP      FALSE(N )   100(100)  STANDBY  84     8485
In dual-active recovery mode: No
#sh switch virt dual-active summary
Pagp dual-active detection enabled: Yes
Bfd dual-active detection enabled: Yes
No interfaces excluded from shutdown in recovery mode
#sh switch virt dual-active pagp
PAgP dual-active detection enabled: Yes
PAgP dual-active version: 1.1
No PAgP channel groups configured
Below are the same commands on a pair of 6509's configured as a vss pair running Version 12.2(33)SXI3.
NDCVSCRMDS01#sh swit virt dual-active summary
Fast-hello dual-active detection enabled: Yes
You have assigned priority 200 to one and 100 to the other one. No need to do that.  When you configure VSS, switch one is always primary and switch 2 is stand-by.  I agreed that you are running a very old code.  You need to move to SXI or SXJ. No enhancemnet is being done is SXH.
Arumugam Muthaiah
I would like to add my comments along with Reza,
When did you started to see this behavior? This issue looks like some enhancement issue issue for the code 12.2(33)SXH. The fix is available in 12.2(33)SXI releases
The ACTIVE LED is showing incorrectly showing as GREEN. In 12.2(33)SXH releases, the color of active LED in standby sup (in VSS) is GREEN. Later changed the standby LED color to ORANGE.
This is not hardware issue.
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
