6504 VSS
George Clark
I have a question im going to convert 2 standalone 6504`s to vss next weekend i did a tac ticket to verify the config and modules
I have applied the template that has been verifyed by them my question is would i see the vsl link active b4 the reboot .
right now it is up and up on both switches but it is not operating as a vsl link at this poing im not sure if it will not be seen until i  switch accept mode virtual i cant do this till a maintence window at 3:00 am just trying to make sure ever thing is good as best i can b4 that date ?????
SWITCH1
switch virtual domain 66
switch 1
switch 1 priority 110
switch 2 priority 100
exit
interface port-channel 66
no shut
desc VSL to switch 2
switch virtual link 1
interface range T5/4 -5
no shutdown
channel-group 66 mode on
SWITCH2switch virtual domain 66
switch 2
exit
interface port-channel 67
no shut
desc VSL to switch 1
switch virtual link 2
no shutdown
channel-group 67 mode on
add this to the PO and members
no switchport
no ip address
balaji.bandi
Check the both kits have same hardware like sup-t, Modules, same IOS.
high level your config look ok. yes all the connection need to be UP before you reload both the switches.
below reference guide
https://community.cisco.com/t5/networking-documents/virtual-switching-system-vss-configuration-for-cisco-4500-series/ta-p/3147865
BB
no switchport
no ip address
