6506 config for VSS using 10G LRM module and 1G Ethernet port
sdevesh
Hi Team,
We have Two 6506-E VSS bundle switches with 2Nos. of 10G LRM modules.
We are trying to implement for VSS between two switches using 10G LRM and 1G Ethenrenet port of each switches. I would like to know that this scenario  will work or not!! If yes pls guide us for the same.
It's URGENT....I am on site...waiting for reply...
Jon Marshall
sdevesh wrote:
Hi Team,
If you mean you want to use the 1Gbps port as part of the VSL link between the 2 switches then no you can't. The VSL is made up of 10Gbps connections of which you can have up to 8.
If you mean an etherchannel connection, again no you cannot mix ports of different speeds in the same etherchannel.
Jon
