Problem with the interface of the express 500
I saw this error in the alert of the express 500 : Detected Ping and/or SYN packets at unexpected rate on this port.
Somebody can help me with this problem, because I dont know why this problem occur.
best regard
Paolo Kobashikawa
Siddharth Chandrachud
Error message:
Explanation:  This message only notifies that the switch is receiving more Pings
or SYN packets than expected.  The device connected to CE500 switch is generating
the SYN/ICMP packets and if you are not experiencing network disruptions this can
be considered as a notification only.  Sometimes if someone is running a 'ping -t'
(continuous ping) and packets hit the interface, one can also see this error.
Hope this helps.
Sid Chandrachud
Cisco TAC.
Error message:
Hope this helps.
Sid Chandrachud
Cisco TAC.
in the alert it´s said error 3 and the recommendation said that i have to take off the device of the port.
The error message indicates a SYN/ICMP packet rate outside the ordinary.
You can check the device connected to CE500 or do a packet capture to find out more about the traffic.
Otherwise, if you do not see any network issues/disruptions you take the message as informational.
- Sid
