6506 upgrade issues
edwin.thompson
Community Member
I've just upgraded my 6506 Supervisor engine (WS-SUP32-GE-3B) to s3223-ipservicesk9_wan-vz.122-18.sxf12.bin. After the initial start I try to do a wr or copy run start and I get a message that the system can not find the start-up config. Has anyone run into this? And how do I get this system back to normal?
6 Replies 6
Edison Ortiz
Please post the show version output.
__
Edison.
Thanks for your help. I got it working , I erased NVRAM and restarted the switch and it recreated the file.
Ryan Carretta
Where are you saving your startup config? This can happen if you, for example, tell the switch to boot from a config file on a flash disk and then the disk is removed.
Try using 'default boot config' and then a write mem...it would be advisable to back up the config first.
Rajat Chauhan
Hi Edwin,
Please paste exact message along with "sh boot"
Raj
