6509 clock module. Needs replacement?
netdood
I have a minor alarm about the clock on a 6509.  Does this mean it needs to be replaced or is it in some kind of standby status?
Here are my two alarms about the clock modules,
Port-Mariners#show environment alarm
environmental alarms:
system minor alarm on operating clock count (raised 21w0d ago)
system minor alarm on clock 2 OK (raised 21w0d ago)
The module doesn't say Fail or anything like I've seen in other user posted output. For example,
https://supportforums.cisco.com/message/546682#546682
sh env
Environmental Status (. = Pass, F = Fail, U = Unknown, N = Not Present)
  PS1: .     PS2: .     PS1 Fan: .     PS2 Fan: .
  Chassis-Ser-EEPROM: .     Fan: .
  Clock(A/B): A         Clock A: .     Clock B: F
  VTT1: .    VTT2: .    VTT3: .
I've read as much as I could find about the clock module but nothing to tell me if it definitely needs to be replaced or is still usable.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_10498.html#wp28321
http://docwiki.cisco.com/wiki/Replace_CLK-7600_WS-C6509-V-E
Here is the complete output from sh environment,
#sh environment
backplane:
  operating clock count: 1
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6K-9SLOT-FAN2
  fan-tray 1 version: 2
  fan-tray 1 fan-fail: OK
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 33C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 33C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 48C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: not OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 power-output-mode: high
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 power-output-mode: high
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 34C
  module 1 inlet temperature: 29C
  module 1 device-1 temperature: 37C
  module 1 device-2 temperature: 31C
  module 1 VDB outlet temperature: 34C
  module 1 VDB inlet temperature: 33C
  module 1 VDB device-1 temperature: 32C
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 30C
  module 2 inlet temperature: 29C
  module 2 device-1 temperature: 29C
  module 2 device-2 temperature: 30C
module 3:
  module 3 power-output-fail: OK
  module 3 outlet temperature: 31C
  module 3 inlet temperature: 29C
  module 3 device-1 temperature: 29C
  module 3 device-2 temperature: 33C
module 4:
  module 4 power-output-fail: OK
  module 4 outlet temperature: 29C
  module 4 inlet temperature: 26C
module 6:
  module 6 power-output-fail: OK
  module 6 outlet temperature: 35C
  module 6 inlet temperature: 29C
  module 6 device-1 temperature: 39C
  module 6 device-2 temperature: 39C
  module 6 asic-1 (SSO-1) temp: 29C
  module 6 asic-2 (SSO-2) temp: 28C
  module 6 asic-3 (SSO-3) temp: 28C
  module 6 asic-4 (SSO-4) temp: 28C
  module 6 asic-5 (SSA-1) temp: 28C
  module 6 asic-6 (HYPERION-1) temp: 29C
  module 6 RP outlet temperature: 29C
  module 6 RP inlet temperature: 29C
  module 6 EARL outlet temperature: 44C
  module 6 EARL inlet temperature: 27C
chassis connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 1
  module 1 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 1 vdb connector rating:  850.08 Watts (20.24 Amps @ 42V)
  module 1 power consumption:  53.76 Watts ( 1.28 Amps @ 42V)
module 2
  module 2 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 2 power consumption: 103.74 Watts ( 2.47 Amps @ 42V)
module 3
  module 3 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 3 power consumption: 103.74 Watts ( 2.47 Amps @ 42V)
module 4
  module 4 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 4 power consumption:  84.00 Watts ( 2.00 Amps @ 42V)
module 6
  module 6 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 6 power consumption: 315.00 Watts ( 7.50 Amps @ 42V)
chassis per slot cooling capacity: 70 cfm
ambient temperature: < 55C
  module 1 cooling requirement: 30 cfm
  module 2 cooling requirement: 30 cfm
  module 3 cooling requirement: 30 cfm
  module 4 cooling requirement: 30 cfm
  module 6 cooling requirement: 35 cfm
netdood
Ended up just replacing the clock module hardware.  Now my status shows both clocks as working.
