6509-E performance issues with two separate modules
andy.bussiere
Community Member
I have a 6509-e with the following four modules:
1   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC
2   16  16 port 1000mb GBIC ethernet           WS-X6416-GBIC
5    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B
6    9  Supervisor Engine 32 8GE (Hot)         WS-SUP32-GE-3B
A few days ago, I started having performance issues with the edge switches connected to the 2nd module (WS-X6416-GBIC) in this 6509-E. I could ping the edge switches connected to the 6416, but they would only reply about half the time, with the other half timing out. I moved all edge switches connected to the 6416 up to the 1st module (WS-X6516A-GBIC). As soon as I moved them, all edge switches started replying more consistant, which is how it's supposed to be.
Three days later, it started again, but on the 6516A. All edge switches connected to the 6516A started timing out during a ping about half the time. As you can expect, my end users are seeing very large performance issues. While physically at the switch, I tried to move a couple edge switches back to the 6416 and the port err-disabled immediately with a UDLD error, UDLD-SP-4-UDLD_PORT_DISABLED.
I then started moving things down to the module 5 supervisor and the edge switches started acting normal again. I did move something to the module 6 supervisor and it err-disabled immedialtey with the same UDLD error.
While in the middle of troubleshooting, I rebooted my 6509-E a couple of times. On one reboot, it booted up to rommom. I then rebooted it again and it came up normal.
Any ideas on what my problem could be?
12 Replies 12
kapathak
Can you paste the outputs from following
#sh spann de ac | i exe|Number of top|from
#show int | i drops| up
#show proc cpu history
#show int from any one of the affected ports
Thanks for the response. See below:
VLAN0001 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 77 last change occurred 02:49:03 ago
          from GigabitEthernet5/7
VLAN0010 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 78 last change occurred 02:49:03 ago
VLAN0028 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 84 last change occurred 02:49:03 ago
VLAN0032 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 79 last change occurred 02:49:03 ago
VLAN0033 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 47 last change occurred 02:49:03 ago
VLAN0034 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 82 last change occurred 02:49:03 ago
VLAN0035 is executing the ieee compatible Spanning Tree protocol
VLAN0036 is executing the ieee compatible Spanning Tree protocol
--More--                                     from GigabitEthernet5/7
VLAN0037 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 38 last change occurred 02:49:05 ago
VLAN0040 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 84 last change occurred 02:49:05 ago
VLAN0044 is executing the ieee compatible Spanning Tree protocol
PBNSTSC-32-13#show int | i drops| up
Vlan32 is up, line protocol is up
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet1/8 is up, line protocol is up (connected)
GigabitEthernet1/12 is up, line protocol is up (connected)
GigabitEthernet1/14 is up, line protocol is up (connected)
GigabitEthernet1/16 is up, line protocol is up (connected)
--More--                             Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet5/1 is up, line protocol is up (connected)
GigabitEthernet5/2 is up, line protocol is up (connected)
GigabitEthernet5/3 is up, line protocol is up (connected)
GigabitEthernet5/4 is up, line protocol is up (connected)
--More--                             Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
GigabitEthernet5/5 is up, line protocol is up (connected)
GigabitEthernet5/6 is up, line protocol is up (connected)
GigabitEthernet5/7 is up, line protocol is up (connected)
GigabitEthernet5/8 is up, line protocol is up (connected)
GigabitEthernet5/9 is up, line protocol is up (connected)
PBNSTSC-32-13#    show proc cpu history
        3333311111333336666622222     222224444477777     1111
100
90
80
70
60
50
40
30
20
10                    *****                    *****
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
               4444
    7776666463424245589679966665655686688565666556566566659655
100
90
80
70
--More--                            60
50
40            *##*
30            *###
20            *###
10 ******* *  ####*******************************************
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
      4  1       12  2 1   23
    9958808998888078879089885
100
90
80
70
60
50   *
40   *                     *
30   *           *  *     **
20   *           *  *     **
10 *************************
--More--                              0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
PBNSTSC-32-13#show int gi1/9
GigabitEthernet1/9 is down, line protocol is down (notconnect)
  Hardware is C6k 1000Mb 802.3, address is 0026.cb57.9580 (bia 0026.cb57.9580)
  Description: PBNSSG-32-34 Gi0/1
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 0/255, rxload 0/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is SX
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 02:51:36, output 02:51:16, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     472390 packets input, 120077663 bytes, 0 no buffer
     Received 50094 broadcasts (31367 multicasts)
     0 watchdog, 0 multicast, 0 pause input
--More--                                0 input packets with dribble condition detected
     4886095 packets output, 914371715 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
PBNSTSC-32-13#show int gi1/9         2.   /16
GigabitEthernet2/16 is down, line protocol is down (err-disabled)
  Hardware is C6k 1000Mb 802.3, address is 0003.32bd.cb78 (bia 0003.32bd.cb78)
  Description: PBNSNSB-32-11 Gi4/2
  Clock mode is auto
  Last input 1d01h, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
PBNSTSC-32-13#
When was the last occurence of the problem?
What is connected to 5/7 ?
The last occurance was 5-9 hours ago on Gi1/9. First is was responding about half the time before it finally disabled itself. See syslog below.
2011-02-23 05:40:20   Local7.Notice  172.27.32.13   445: Feb 23 11:38:35.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9, changed state to down
2011-02-23 05:40:20   Local7.Error     172.27.32.13   446: Feb 23 11:38:35.235: %LINK-3-UPDOWN: Interface GigabitEthernet1/9, changed state to down
2011-02-23 05:40:20   Local7.Warning            172.27.32.13   447: Feb 23 11:38:35.211: %UDLD-SP-4-UDLD_PORT_DISABLED: UDLD disabled interface Gi1/9, unidirectional link detected
2011-02-23 05:40:20   Local7.Warning            172.27.32.13   448: Feb 23 11:38:35.211: %PM-SP-4-ERR_DISABLE: udld error detected on Gi1/9, putting Gi1/9 in err-disable state
2011-02-23 05:40:21   Local7.Notice  172.27.32.13   449: Feb 23 11:38:35.243: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/9, changed state to down
2011-02-23 05:40:21   Local7.Error     172.27.32.13   450: Feb 23 11:38:35.243: %LINK-SP-3-UPDOWN: Interface GigabitEthernet1/9, changed state to down
2011-02-23 05:40:22   Local7.Warning            172.27.32.13   451: Feb 23 11:38:35.343: %PM-SPSTBY-4-ERR_DISABLE: udld error detected on Gi1/9, putting Gi1/9 in err-disable state
I moved the edge switch after this error from Gi1/9 to Gi5/7. Since then, it's been running fine.
So, is this problem seen with mutiple edge switches or  any particular edge switch. I would also check the health of fibres and the sfps. UDLD can sometimes erroneously put a port into errdisabled if any one of the switches at either end has High CPU which may utimately result in a failure to send UDLD keepalives.
This issue is with all edge switches connected through these modules. There are 14 different edge switches connected using 14 different routes and GBICs.
Do you think the IOS could be corrupt or the primary sup32 could be failing?
What's the output of "show spanning-tree root"?
PBNSTSC-32-13#show spanning-tree root
                                        Root Hello Max Fwd
Vlan                   Root ID          Cost  Time Age Dly  Root Port
VLAN0001           100 00d0.050c.4000         4    2   20  15  Gi5/8
VLAN0010           100 00d0.050c.4009         4    2   20  15  Gi5/8
VLAN0028           100 00d0.050c.401b         4    2   20  15  Gi5/8
VLAN0032           100 00d0.050c.401f         4    2   20  15  Gi5/8
VLAN0033         32768 0007.0e8c.c484         8    2   20  15  Gi1/16
VLAN0034           100 00d0.050c.4021         4    2   20  15  Gi5/8
VLAN0035           100 00d0.050c.4022         4    2   20  15  Gi5/8
VLAN0036           100 00d0.050c.4023         4    2   20  15  Gi5/8
VLAN0037           100 00d0.050c.4024         8    2   20  15  Gi1/14
VLAN0040           100 00d0.050c.4027         4    2   20  15  Gi5/8
VLAN0044           100 00d0.050c.402b         4    2   20  15  Gi5/8
What's attached to port 5/8, 1/14 and 1/16?  I'm not sure of your topology, but I would assume you want your 6509 to be the root for all those VLANs.  Make sure it has a higher priority then the access switches that are attached.
This is not the core switch. The core switch is connected to 5/8 and should be the root for all VLANS with the expection of 33, which is a different 6509 (Gi1/16), due to the isolation of the 33 VLAN. The only question is the 37 VLAN, which isn't used, but it's showing 1/14 as the root when it should be 5/8. As I said though, 37 isn't used.
Any other thoughts?
Not sure.  Are any of the links overly saturated?  Has this EVER worked, or did it just suddenly start acting up now?  Any recent iOS upgrades or other changes changes?  I would try opening a TAC case.  I'm curious about the resolution to this, so if you do open up a TAC case please post back what they tell you.
Thank you all for your help. The issue ended up being a bad supervisor. As soon as I switched to the back
up supervisor, everything started working correctly.
Thank you for the comments and suggestions.
