6509 IOS Upgrade question/issue
Bradford.berry
Hello I havea 6509 running c6sup2_rp-PSV-M I wat to upgrade it to  s222-ipservicesk9_wan-mz.122-18.SXF17b, I have loaded the IOS onto my compactflash and set the boot to the new file, when i reloaded the secondary Sup2 it didnt come back online.
My Question is what did i miss? do i need to change the bootldr?
here is my conifg:
Show bootvar:
BOOT variable = sup-bootflash:c6sup22-psv-mz.121-27b.E3.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:c6msfc2-boot-mz.121-20.E2
show version:
IOS (tm) c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(27b)E3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 07-Aug-07 10:01 by hqluong
Image text-base: 0x40008F90, data-base: 0x4185C000
ROM: System Bootstrap, Version 12.2(17r)S5, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(27b)E3, RELEASE SOFTWARE (fc1)
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootflash:c6sup22-psv-mz.121-27b.E3.bin"
cisco WS-C6509 (R7000) processor (revision 2.0) with 227328K/34816K bytes of memory.
Processor board ID SCA04520015
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
14 Virtual Ethernet/IEEE 802.3  interface(s)
336 FastEthernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Dir disk0:
Directory of disk0:/
    1  -rw-    51356164  Oct 22 2011 08:12:22 +00:00  s222-ipservicesk9_wan-mz.122-18.SXF17b.bin
64278528 bytes total (12918784 bytes free)
Thanks for the help.
Brad
Can you show
sh redundancy
sh boot
now?
Did show boot shows you standby boot configuration?
Did you tryed to connect to standby unit via console? What does it says?
Eugene Khabarov
Level 7
Level 7
Did you loaded s222-ipservicesk9_wan-mz.122-18.SXF17b to slavesup-bootflash: ?
Did you set your boot loader variable like this:
boot system flash slavesup-bootflash:s222-ipservicesk9_wan-mz.122-18.SXF17b.bin
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer."
I loaded the File into disk0: and slavedisk0: and then set the boot to the following
boot system flash disk0:s222-ipservicesk9_wan-mz.122-18.SXF17b.bin
Brad
Can you show
sh redundancy
sh boot
now?
I called tac, and then reliaze that the sup2's didnt have enough memory to support the IOS.
I have memory on order and once upgraded It should load fine.
Thanks for you help though Eugune.
Brad
