6509 issue image upgrade doesnt work
amit bhatnagar
Hello we have cisco 6500 , in which we are trying to upgrade image using ISSU process , new image is s2t54-adventerprisek9-mz.SPA.151-1.SY1.bin, but even we follow the suggested steps it still boots with old image , do we need to follow the old steps "boot system image "
load image in bootdisk
issu loadversion primary existing image secondary new image
issu runversion
issu acceptversion
issu commitversion
please advise
regards
amit
we need to follow ISSU steps right ?
You can, if you want to.  But what I've posted is the better way because some IOS don't support ISSU (and in some cases, some IOS break ISSU).
please advise thanks
I need to sleep.  Give me a break!
9 Replies 9
Leo Laohoo
post the output to the command "sh bootvar".
Sandeep Choudhary
HI Amit,
First check memory on flash card..... backup old IOS and config from swicth.
then
Download new image:
Cat6509> (enable) copy tftp bootflash:
Cat6509> (enable) dir bootflash:
Change the boot variable so that the switch boots with new software image after reset.
Cat6509> (enable) show boot
Cat6509> (enable) clear boot system flash bootflash:cat6000-sup2.6-3-6.bin ----(clear the old image )
Cat6509> (enable) set boot system flash bootflash:cat6000-sup2cvk8.7-3-2.bin
Reset the switch so that during reload, the switch boots with the new software image.
Cat6509> (enable) reset
Verify whether the switch loads the new software image.
Cat6509> (enable) show version
Hope it helps.
Reagrds
Dont forget to rate helpful posts.
hello leo ,
please find output of bootvar below
#sh boot
DRG_SW00_6509_LO6E#sh bootv
DRG_SW00_6509_LO6E#sh bootvar
BOOT variable = bootdisk:,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby BOOT variable = bootdisk:,1;
Standby CONFIG_FILE variable =
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
Try this:
conf t
boot sys flash sup-bootflash:s2t54-adventerprisek9-mz.SPA.151-1.SY1.bin
end
wr
hello Leo , so ISSU process doesnt work in that case ? and the command you have mentioned is it service affecting as there are 2 6509 in VSS
1.  Copy the IOS to the primary sup-bootflash using this command:  copy tftp:///filename.bin sup-bootflash:
2.  Copy the IOS to the secondary sup-bootflash using this command:  copy tftp:///filename.bin slavesup-bootflash:
3.  Change the bootstring:  boot system flash sup-bootdisk:filename.bin
thanks leo after giving command
3.  Change the bootstring:  boot system flash sup-bootflash:filename.bin
regards
amit
