6509 - lcp failed to go online issue....
jimmysands73_2
Level 5
Level 5
Got call saying some users were down, found root cause, card dead on a 6509.
*Nov 9 20:52:41.310: SP: oir_disable_notice: slot6: lcp failed to go online
*Nov 9 20:52:41.310: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off (Reset)
from line card in module 6 on our 6509.  Status light is not lit up.  Tried
0564-RTR-01#hw-module module 6 reset
Proceed with reload of module? [confirm]
Didnt help.
Tried reseeating the card, didnt help.
I moved module 6 (model WS-X6348) to open bay 9, same issue.
Nov 9 14:36:04.114: %OIR-SP-6-REMCARD: Card removed from slot 6, interfaces disabled
Nov 9 14:40:06.303: %OIR-SP-6-PWRFAILURE: Module 9 is being disabled due to power convertor failure
Nov 9 14:40:06.303: SP: oir_disable_notice: slot9: lcp failed to go online
Nov 9 14:40:31.983: %OIR-SP-6-REMCARD: Card removed from slot 9, interfaces disabled
Back in slot 6:
0564-RTR-01#show diagnostic module 6
Current Online Diagnostic Level = Minimal
Online Diagnostic[Module 6]: Card is not detected.
0564-RTR-01#show diagnostic content module 6
Card is kaput?  A router reload was already performed, it has worked w/no issues the past few years.
2 Accepted Solutions
seems like it's a faulty card. ask an RMA.
Hi Jimmy,
I've replaced an RJ45 line card before (4507) but haven't encountered similar issue. Are you using the same card type? I hope you have a backup config.
5 Replies 5
jimmysands73_2
Level 5
Level 5
It also said in log regarding module 6:
Nov  9 12:52:39.632: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan25, changed state to down
Nov  9 12:52:39.636: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan26, changed state to down
Nov  9 20:52:41.310: %OIR-SP-6-PWRFAILURE: Module 6 is being disabled due to power convertor failure
Nov  9 12:52:51.692: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimum Online Diagnostics...
There is a module phuysical in 6 right now....
0564-RTR-01#sh power
system power redundancy mode = redundant
system power total =     1153.32 Watts (27.46 Amps @ 42V)
system power used =       653.52 Watts (15.56 Amps @ 42V)
system power available =  499.80 Watts (11.90 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-1300W       1153.32 27.46  OK     OK     on
2    WS-CAC-1300W       1153.32 27.46  OK     OK     on
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6K-SUP2-2GE     142.38  3.39   142.38  3.39  on    on
2    WS-X6408A-GBIC      142.38  3.39   142.38  3.39  on    on
3    WS-X6408A-GBIC       84.00  2.00    84.00  2.00  on    on
4    WS-X6408A-GBIC       84.00  2.00    84.00  2.00  on    on
5    WS-X6348-RJ-45      100.38  2.39   100.38  2.39  on    on
6    WS-X6348-RJ-45      100.38  2.39     -     -     on    off (Module Removed)
7    WS-X6348-RJ-45      100.38  2.39   100.38  2.39  on    on
Yup, changing it out as we speak.  I was shocked to find the startup config did not have a listing for port 6/1 - 48....if those ports are not on a operational line card does the 6500 series not show them in its config?  All I saw on the ints after I put the card in was:
interface FastEthernet6/1
no ip address
interface FastEthernet6/2
no ip address interface FastEthernet6/1
no ip address
no ip address
etc....looking for backup config now.
Hi Jimmy,
Yeah, it was odd...in the config there was no mention of fa6/1 - 48....anyways, got the back from the depository and all is well again
