6509 not showing static routes
shahkalpeshj
Hi Guys,
I have two new 6509Es that I have connected to the network.  The  issue is that the two are connected via a port-channel and then the one  6509 is connected via a port channel to the main core switch (6509E).   The problem is that the one connected to the main core switch shows the  static routes configured on them when I do a show ip route static, but  the main problem is that on the other new core when I do the same  command show ip route, it just displays the connected routes.  I tried  using the command ip routing but then it gives an incomplete command on  the 6509.
6509(does not show static routes)---->6509 (shows all routes)---->6509 (main core switch)
connected via port-channel-------80------------conn via a port channel------------81
any help would be greatly appreciated.
You only have 2 vlans configured with IP addresses as shown below:
interface Vlan252
ip address 10.252.0.5 255.255.0.0
interface Vlan303
ip address 10.203.3.5 255.255.255.0
You have static routes configured, but the next hop IP address in not valid.  Your next hop ip address defined in your static routes should be in the same subnet as 10.252.0.0/16 or 10.203.3.0/24 They are all pointing to 10.250.1.193 and
10.204.19.105 and 10.204.19.100 and so on.  Also, all your portchannels are layer-2  and not layer-3
12 Replies 12
Reza Sharifi
By default, IP routing is enabled on the 6500 series switches.   Is this new 6500 layer 3 or you are using it as layer-2?
If it is layer-2 only, than there should not be any static route, only connected. Is portchannel 80 layer-2 or layer-3?
thanks for the prompt response.
it is a new layer 3 6509E.  The port-channel is layer 2.
It is that we are replacing the old cores and what I have done is just copied the old config and pasted on this new core, but the issue that I am facing now is that out of the two new cores; one shows all the static routes, but then the second one does not display any routes other than connected.
Can you post "sh run"?
Also, if you have configured static routes, it order for them to show up in the routing table, the interfaces need to be in up and up mode.
can you also post "sh ip route"?
hostname Ess0203
boot system flash disk0:s72033-ipservicesk9-mz.122-18.SXF11.bin
boot system flash sup-bootflash:s72033-pk9s-mz.122-18.SXD3.bin
logging buffered 16384 debugging
no logging console
enable secret 5 $1$6GYz$M0mcVmrboVaM1ahEnNWeZ0
username admin password 7 14041E0E1C1633
aaa new-model
aaa authentication login default group tacacs+ local
aaa session-id common
clock timezone est -5
clock summer-time EDT recurring
ip subnet-zero
ip domain-name mgt.stj.homehardware.ca
ip name-server 10.204.22.35
ip name-server 10.204.22.36
vtp domain homehardware
vtp mode transparent
mls ip multicast flow-stat-timer 9
mls aging long 64
mls aging normal 64
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos map ip-prec-dscp 0 8 16 26 32 46 48 56
mls qos
no mls acl tcam share-global
mls cef error action freeze
redundancy
mode sso
main-cpu
  auto-sync running-config
spanning-tree mode pvst
spanning-tree portfast bpduguard default
no spanning-tree optimize bpdu transmission
spanning-tree uplinkfast
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
errdisable recovery cause bpduguard
errdisable recovery interval 600
fabric buffer-reserve queue
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
vlan 9
name vl009
vlan 11
name vl011
vlan 12
name vl012
vlan 14
name vl014
vlan 15
name vl015
vlan 16
name vl016
vlan 17
name vl017
vlan 18
name vl018
vlan 19
name vl019
vlan 20
name vl020
vlan 21
name vl021
vlan 22
name vl022
vlan 23
name vl023
vlan 24
name vl024
vlan 25
name VL025
vlan 26
name vl026
vlan 27
name vl027
vlan 28
name vl028
vlan 29
name vl029
vlan 30
name vl030
vlan 40
name vl040
vlan 41
name vl041
vlan 42
name vl042
vlan 43
name vl043
vlan 50
name vl050
vlan 51
name vl051
vlan 60
name vl060
vlan 61
name vl061
vlan 62
name vl062
vlan 63
name vl063
vlan 64
name vl064
vlan 98
name vl098
vlan 99
name vl099
vlan 101
name STJ_CR_Old-Server
vlan 121
name STJ_CR_Servers-2
vlan 122
name vl122
vlan 124
name vl124
vlan 125
name vl125
vlan 160
name vl160
vlan 161
name vl161
vlan 175
name vl175
vlan 180
name vl180
vlan 200
name vl200
vlan 202
name vl202
vlan 204
name vl204
vlan 208
name vl208
vlan 217
name vl217
vlan 218
name vl218
vlan 224
name vl224
vlan 251
name vl251
vlan 252
name vl252
vlan 253
name vl253
vlan 303
name vl303
vlan 501
name vl501
vlan 502
name vl502
vlan 503
name vl503
vlan 504
name vl504
vlan 507
name vl507
vlan 508
name vl508
vlan 509
name vl509
vlan 510
name vl510
vlan 802
name vl802
vlan 853
name vl853
vlan 854
name vl854
vlan 855
name vl855
vlan 900
name vl900
remote-span
vlan 910
name vl910
vlan 911
name vl911
vlan 913
name vl913
vlan 914
name vl914
vlan 921
name vl921
vlan 922
name vl922
vlan 923
name vl923
vlan 924
name vl924
vlan 988
name vl988
vlan 989
name vl989
vlan 991
name vl991
vlan 993
name vl993
vlan 995
name vl995
vlan 997
name vl997
vlan 998
name vl998
vlan 999
name Native_VLAN
class-map match-any VOICE_SIG
  match access-group name QOS_VOICE_SIG
  match access-group name QOS_VOICE_DATA
policy-map QOS
  class VOICE
   set dscp ef
  class VOICE_SIG
   set dscp cs4
interface Port-channel1
description [GEC] ESE0202 - ESE0203
switchport
switchport trunk native vlan 999
switchport mode trunk
no ip address
mls qos trust dscp
interface Port-channel2
description "Port Channel to VC1Flex10"
switchport
no ip address
interface Port-channel8
switchport
no ip address
mls qos trust dscp
interface Port-channel3
description "Port Channel to VC2Flex10"
switchport
switchport trunk allowed vlan 11,12,14,15,17,18,24,25,98,101,121,122,252,502
switchport trunk allowed vlan add 910,911,989
no ip address
shutdown
interface Port-channel14
description connected to Ess0073
switchport
no ip address
mls qos trust dscp
interface Port-channel24
switchport
no ip address
mls qos trust dscp
interface Port-channel26
description connected to Ese0231 po0/19,20
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet1/1
description Uplink to Furniture Warehouse-Cafeteria
switchport
no ip address
wrr-queue queue-limit 85 5 5
mls qos trust dscp
interface GigabitEthernet1/2
description Rts016 - GE 0/1 - VoiP Gateway - Elm
switchport
switchport access vlan 21
switchport mode access
no ip address
mls qos trust dscp
spanning-tree bpduguard enable
interface GigabitEthernet1/3
description connected to ESE0186 port 1/0/26
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet1/4
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/5
description connected to ESE0009 port 0/2
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet1/6
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/7
description connected to Ess0073 port 1/17
switchport
no ip address
mls qos trust dscp
channel-group 14 mode on
interface GigabitEthernet1/8
switchport
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/9
description connected to Ess0166 port G2/0/25
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet1/10
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/11
description Uplink to Ess0286
switchport
no ip address
mls qos trust dscp
channel-group 24 mode on
interface GigabitEthernet1/12
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet1/13
description Uplink to Ess0273-Elm Whse 'Martins'
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet1/14
description Ble416e2 x1 Sus-B
switchport
no ip address
mls qos trust dscp
spanning-tree portfast trunk
channel-group 8 mode active
interface GigabitEthernet1/15
description Ble416e2 x2 Sus-B
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet1/16
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/17
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/18
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/19
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/20
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/21
switchport
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/22
switchport
no ip address
mls qos trust dscp
channel-group 26 mode on
interface GigabitEthernet1/23
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet1/24
description connected to ESS0103
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet2/1
description bleb528e2 x2 Sus-A po2
switchport
no ip address
channel-group 2 mode active
interface GigabitEthernet2/2
description bleb528e2 x3 Sus-A po2
switchport
no ip address
interface GigabitEthernet2/3
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/4
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/5
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/6
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/7
description Connected to Ess0073 port 1/18
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet2/8
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/9
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/10
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/11
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/12
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/13
description Srs432-E4d-backup
switchport
switchport trunk allowed vlan 17,999
no ip address
interface GigabitEthernet2/14
description Srs435-E4d-backup
switchport
no ip address
interface GigabitEthernet2/15
switchport
no ip address
shutdown
interface GigabitEthernet2/16
switchport
no ip address
shutdown
interface GigabitEthernet2/17
switchport
no ip address
shutdown
interface GigabitEthernet2/18
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/19
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/20
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/21
switchport
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/22
switchport
no ip address
mls qos trust dscp
interface GigabitEthernet2/23
no ip address
shutdown
mls qos trust dscp
interface GigabitEthernet2/24
no ip address
shutdown
interface GigabitEthernet5/1
description connected to ESE0202
switchport
no ip address
wrr-queue queue-limit 90 5
mls qos trust dscp
channel-group 1 mode on
interface GigabitEthernet5/2
switchport
no ip address
mls qos trust dscp
interface Vlan1
no ip address
shutdown
interface Vlan252
ip helper-address 10.204.22.35
ip helper-address 10.204.22.36
standby 1 ip 10.252.0.1
standby 1 timers msec 200 msec 750
standby 1 authentication 7d3HwuXT
interface Vlan303
ip policy route-map Guest-Traffic
interface Vlan849
description MUST disable igmp snooping
no ip address
shutdown
interface Vlan851
no ip address
interface Vlan852
no ip address
ip default-gateway 10.252.0.1
ip classless
ip forward-protocol udp 1761
ip route 0.0.0.0 0.0.0.0 10.250.1.193
ip route 10.201.1.0 255.255.255.0 10.250.1.193
ip route 10.219.21.0 255.255.255.0 10.204.19.105
ip route 10.219.22.0 255.255.255.0 10.204.19.105
ip route 10.219.23.0 255.255.255.0 10.204.19.105
ip route 10.219.24.0 255.255.255.0 10.204.19.105
ip route 10.225.115.0 255.255.255.0 10.254.252.2
ip route 10.248.0.0 255.255.0.0 10.250.1.193
ip route 10.249.0.0 255.255.0.0 10.250.1.193
ip route 10.250.1.192 255.255.255.192 10.250.1.193
ip route 10.250.251.0 255.255.255.0 10.250.1.193
ip route 10.250.252.0 255.255.255.0 10.250.1.193
ip route 10.250.253.0 255.255.255.0 10.250.1.193
ip route 10.254.10.0 255.255.255.0 10.204.19.100
ip route 10.254.11.0 255.255.255.0 10.204.19.100
ip route 10.254.12.0 255.255.255.0 10.204.19.100
ip route 10.254.13.0 255.255.255.0 10.204.19.100
ip route 10.254.14.0 255.255.255.0 10.204.19.100
ip route 10.254.15.0 255.255.255.0 10.204.19.100
ip route 10.254.74.0 255.255.255.0 10.250.1.193
ip route 10.254.75.0 255.255.255.0 10.250.1.193
ip route 10.254.76.0 255.255.255.0 10.250.1.193
ip route 10.254.77.0 255.255.255.0 10.250.1.193
ip route 10.254.84.0 255.255.255.0 10.250.1.193
ip route 10.254.85.0 255.255.255.0 10.250.1.193
ip route 10.254.86.0 255.255.255.0 10.250.1.193
ip route 10.254.87.0 255.255.255.0 10.250.1.193
ip route 10.254.89.0 255.255.255.0 10.204.19.100
ip route 192.168.1.0 255.255.255.0 10.250.1.193
ip route 192.168.12.0 255.255.255.0 10.254.252.2
ip flow-export source GigabitEthernet5/1
ip flow-export version 9
ip flow-export destination 10.201.175.232 2055
no ip http server
ip access-list extended Guest-Internet-Return-ACL
permit ip any 10.150.208.0 0.0.3.255
permit ip any 10.150.224.0 0.0.15.255
permit ip any 10.150.212.0 0.0.3.255
permit ip any 10.150.216.0 0.0.0.255
permit ip any 10.192.51.0 0.0.0.255
permit ip any 10.194.51.0 0.0.0.255
permit ip any 10.195.51.0 0.0.0.255
permit ip 10.254.91.0 0.0.0.255 any
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 192.0.0.0 0.255.255.255
deny   ip any 172.16.0.0 0.15.255.255
permit ip any any
ip access-list extended Guest-Traffic
deny   udp any host 10.204.22.35 eq bootps
deny   udp any host 10.204.22.36 eq bootps
permit ip 10.150.208.0 0.0.3.255 any
permit ip 10.150.224.0 0.0.15.255 any
permit ip 10.150.212.0 0.0.3.255 any
permit ip 10.150.216.0 0.0.3.255 any
permit ip 10.192.51.0 0.0.0.255 any
permit ip 10.194.51.0 0.0.0.255 any
permit ip 10.195.51.0 0.0.0.255 any
deny   ip any any
ip access-list extended QOS_BULK
permit tcp any any range 49152 49162
permit tcp any any range 5555 5575
permit tcp any any range 18000 18009
ip access-list extended QOS_CRITICAL
permit ip host 10.101.100.193 any
permit ip any host 10.101.100.193
ip access-list extended QOS_DATA-MED
permit ip 10.0.0.0 0.255.255.255 any
permit ip any 10.0.0.0 0.255.255.255
ip access-list extended QOS_NET_MANAGER
permit udp any any eq snmp
permit udp any any eq snmptrap
permit udp any any eq syslog
ip access-list extended QOS_SCAVENGER
deny   ip any any
ip access-list extended QOS_VIDEO
deny   ip any any
ip access-list extended QOS_VOICE_DATA
permit udp any any range 16384 32767
ip access-list extended QOS_VOICE_SIG
permit tcp any any range 2000 2002
ip access-list extended Wireless-Guest-ACL
permit udp any host 1.1.1.1 eq bootpc
permit udp any host 1.1.1.1 eq bootps
permit udp any host 10.204.22.35 eq bootpc
permit udp any host 10.204.22.35 eq bootps
permit udp any host 10.204.22.36 eq bootpc
permit udp any host 10.204.22.36 eq bootps
permit udp any host 10.204.17.22 eq bootpc
permit udp any host 10.204.17.22 eq bootps
permit ip any 10.254.91.0 0.0.0.255
permit ip any any
ip access-list extended Wireless-Handhelds-ACL
permit udp any any eq domain
permit udp any any eq bootpc
permit udp any any eq bootps
permit ip any host 10.122.20.119
permit ip any host 10.125.20.128
permit ip any host 10.122.20.162
permit ip any host 10.122.20.163
permit ip any host 10.122.21.14
permit ip any host 10.122.20.165
permit ip any host 10.121.20.110
permit ip any host 10.204.22.35
permit ip any host 10.204.22.36
permit ip any 10.204.11.0 0.0.0.255
permit ip any host 10.250.3.209
deny   ip any any
ip access-list extended vlan_122
permit ip host 10.122.21.43 10.195.0.0 0.0.255.255
permit ip host 10.122.21.43 10.194.0.0 0.0.255.255
permit ip host 10.122.21.43 10.192.0.0 0.0.255.255
logging trap warnings
logging facility local5
logging 10.122.20.100
logging 10.252.21.62
access-list 94 permit 10.204.24.22
access-list 94 permit 10.204.12.30
access-list 94 deny   any
access-list 95 permit 10.252.21.62
access-list 97 permit 10.122.20.100
access-list 97 permit 10.101.0.0 0.0.255.255
access-list 97 permit 10.252.0.0 0.0.255.255
access-list 97 permit 10.250.248.0 0.0.0.255
access-list 97 permit 10.195.0.0 0.0.255.255
access-list 97 permit 10.194.0.0 0.0.255.255
access-list 97 permit 10.192.0.0 0.0.255.255
access-list 97 deny   any
access-list 98 permit 10.122.20.100
access-list 98 permit 10.101.100.193
access-list 98 permit 10.204.15.41
access-list 98 permit 10.252.0.0 0.0.255.255
access-list 98 deny   any
access-list 177 permit udp host 10.122.21.43 any eq 1761
route-map Guest-Traffic permit 10
match ip address Guest-Traffic
set ip next-hop 10.254.91.4
snmp-server community ccshhsl RO 98
snmp-server community BmqE2r5kh!9w RW 95
snmp-server community GpqR8r3eh!7y RO 94
snmp-server contact mis@homehardware.ca
snmp-server enable traps config
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server host 10.122.20.100 ccshhsl
snmp-server host 10.252.22.35 ccshhsl
snmp-server file-transfer access-group 98 protocol tftp
snmp-server tftp-server-list 98
tacacs-server host 10.252.20.175
tacacs-server host 10.252.20.164
tacacs-server directed-request
tacacs-server key 7 141C130D09012424273C3C372701
radius-server source-ports 1645-1646
control-plane
dial-peer cor custom
line con 0
exec-timeout 0 0
line vty 0 4
access-class 97 in
password 7 05080F1C2243
line vty 5 15
password 7 060506324F41
ntp clock-period 17179861
ntp server 10.252.0.2 prefer
ntp server 10.204.22.35
no cns aaa enable
end
the two connected routes that it shows are the vlan interfaces that aree there.
thanks
interface Vlan252
interface Vlan303
that is right, but the ip add 10.250.1.193 is the firewall's add and that is what it is pointing to.  This config has been working all right up until now on the old core, I just had to paste it on the new one and all of a sudden all i am facing is that it is not showing any routes.  as a result I have also given the default gateway for 10.252.0.1 for this.
is it possible that enabling ospf on this would solve the issue?
Ok, what is the IP address of the interface connecting the new 6500 to the other 6500?
Can you post diagram and show what IP addresses belong to which interface and what router?
If you are connecting the 2 6500 via an etherchannel and you want it to be layer-3 than the etherchannel interface needs IP
draw a diagram
When IP routing is enabled (which is by default on the 6500) you don't need to define a default gateway.  Default gateway is used when the switch is layer-2 only.  So, you can remove it.  If the firewall's IP is in the 10.250.1.193 range, but than I don't see any physical interface or vlan SVI in this range.
i guess if i use OSPF this might solve the issue.  as at the moment the old core is enabled with ospf and I did not enable ospf on the new one, so I guess that once ospf is enabled on this, i would be able to see all the routes.  Do you think this is the right thing?
this is the rough picture about how the cores are connected.  everything is fine (shows all routes) on 343,344 and 348.
they are all connected via layer 2 with ospf as the main routing protocol.  I have not enabled ospf on the new ones as I have not added the new cores to the firewall cluster, but I have a feeling that once I do add them to the firewall cluster as well as put ospf configs on the new cores, I guess I would be able to put them on the new cores.
