6509 randomly drop packet
My workstation(10.0.0.250) directly connected to 6509_1 switch. 6509_1 is gateway with ip 10.0.0.5/22.
Sometimes routing stop working, but after 3-5 minutes all back to normal.
When issue occur i can't ssh to 6509_1, but i connect to second 6509_2 (10.0.0.6) and i can ssh to 6509_1 from it.
Then form 6509_1 i try to ping my workstation
Wireshark on my workstation show that packet arrive. My workstation reply on it, but switch not accept it
How it possible? As I say after sometime all go back to normal without any changes.
I try to debug ip packet when issue occur
access-list 171 permit ip host 10.0.05 host 10.0.0.250
debug ip packet detail 171
I get only log like this:
Nov  2 12:46:41.319:  IP: s=10.0.1.247, d=224.0.0.252, pak 5008BD40 consumed in input feature  , packet consumed, MCI Check(55), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:41.427:  IP: s=10.0.1.247, d=224.0.0.252, pak 46864C48 consumed in input feature  , packet consumed, MCI Check(55), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:42.291: IP: s=10.0.0.5 (local), d=10.0.0.250, len 100, local feature
Nov  2 12:46:42.291:     ICMP type=8, code=0 , NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:42.291: FIBipv4-packet-proc: route packet from (local) src 10.0.0.5 dst 10.0.0.250
Nov  2 12:46:42.291: FIBipv4-packet-proc: packet routing succeeded
Nov  2 12:46:42.291: IP: tableid=0, s=10.0.0.5 (local), d=10.0.0.250 (Vlan6), routed via FIB
Nov  2 12:46:42.291: IP: s=10.0.0.5 (local), d=10.0.0.250 (Vlan6), len 100, sending
Nov  2 12:46:42.291: IP: s=10.0.0.5 (local), d=10.0.0.250 (Vlan6), len 100, output feature
Nov  2 12:46:42.291:     ICMP type=8, code=0 , NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:42.291: IP: s=10.0.0.5 (local), d=10.0.0.250 (Vlan6), len 100, post-encap feature
Nov  2 12:46:42.291:     ICMP type=8, code=0 , MTU Processing(4), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:42.291:     ICMP type=8, code=0 , IP Protocol Output Counter(5), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:42.291:     ICMP type=8, code=0 , IP Sendself Check(8), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:42.291:     ICMP type=8, code=0 , HW Shortcut Installation(15), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Nov  2 12:46:42.291: IP: s=10.0.0.5 (local), d=10.0.0.250 (Vlan6), len 100, sending full packet
Nov  2 12:46:49.095:  IP: s=10.0.2.254, d=224.0.0.252, pak 468BC354 consumed in input feature  , packet consumed, MCI Check(55), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
As I understand packet sended but no reply.
Can any one point how troubleshoot it?
Raju Sekharan
Does your server has multiple connections to network?
During the issue are other devies in subnet 10.0.0.0/22, able to  ping  10.0.0.5?
After some hours of searchinng I found new device with ip 10.0.0.5 which conflict with gateway. Issue solved. Anyway thanks.
