6509 rate-limit not supported, service-policy help
acomiskey
Level 10
Level 10
I am attempting to transfer the following config to a 6509. When I try to use the command it says it is not supported by hardware, use service-policy instead. Could someone help me get started? thanks.
rate-limit input 30720000 15360 30720 conform-action transmit exceed-action drop
rate-limit output 30720000 15360 30720 conform-action transmit exceed-action drop
Jon Marshall
Adam
You don't say which version of software you have on your 6500 but assuming a version of 12.2SXF. I'm also assuming a PFC3 on a supervisor 720. If any of this is wrong please come back.
You need to use MQC syntax for this. From Cisco configuration docs
Note: Policers can act on ingress traffic per-port or per-VLAN. With a PFC3, for egress traffic, the policers can act per-VLAN only. So is it enough to police the interface ingress only ?
Anyway attached is a link to the doc mentioned above with an example of how to police traffic coming in on an interface. The link i have posted takes you straight to the example but the chapter is on configuring QOS for 6500.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1751025
Have a look and please come back if you have further questions.
Jon
Sorry Jon, I'm a bit of a noob with this equipment.
#show module
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP xxxxxx
2 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX xxxxxx
5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE xxxxxx
Mod MAC addresses Hw Fw Sw Status
1 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 2.2 12.2(14r)S5 12.2(18)SXD7 Ok
2 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 6.1 7.2(1) 8.3(0.156)RO Ok
5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 3.5 8.4(2) 12.2(18)SXD7 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC xxxxxxxxxxx 2.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3A xxxxxxxxxxx 2.4 Ok
5 MSFC3 Daughterboard WS-SUP720 xxxxxxxxxxx 2.8 Ok
(I sure with that these posts took spaces)
Here is what I have tried so far..
policy-map ISP_Inbound
class 30mb
police 30720000 15360 30720 conform-action transmit
exceed-action drop
policy-map ISP_Outbound
class 30mb
exceed-action drop
class-map match-all 30mb
match access-group 105
access-list 105 permit ip any any
int Gi2/7
bandwidth 30000
service-policy input ISP_Inbound
service-policy output ISP_Outbound
Adam
No problem. Are you saying that the config you have applied is not working or not ?
FYI - you do have a Supervisor 720 with a PFC3.
Jon
Honestly, I'm not entirely sure what the config is supposed to do or how to check if it's working. I can do "show mls qos", "show mls qos ip gi2/7" etc. and see counters increasing. A little background info. A client was experiencing Citrix sessions dropping occasionally during periods of congestion. The ISP added the "rate-limit" config I posted before. They then asked if we could put the same thing on the clients end. When I tried, I received the message saying that the hardware does not support it. I then tried to transfer that config to the 6509 and this is what I came up with.
