High CPU Load! Help!
volkovvalery
Level 2
Level 2
Cisco 2851
#sh processes cpu sorted 5min
CPU utilization for five seconds: 98%/6%; one minute: 98%; five minutes: 98%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
291 3560472 1091595 3261 87.94% 89.21% 89.47% 0 CCSIP_UDP_SOCKET
CCSIP_UDP_SOCKET causes high CPU Usage
Symptom Incoming and outgoing calls fail due to high CPU Usage.
Conditions CPU Usage is at 99-100% and CCSIP_UDP_SOCKET is using 88+%.
Workaround There is no workaround.
What can i do to solve the problem?
Richard Burts
Valery
What you are quoting sounds like there is a problem in the version of code that you are running. Perhaps it is time to think about an upgrade of the code that you are running (or perhaps a down grade, depending on what you are running).
Rick
Rick
Now running c2800nm-adventerprisek9_ivs-mz.124-15.T4.bin
Which version more stable?
Valery
I see in the software download center that there is a slightly newer version of the code - 12.4(15)T5. Or if you want to go down a bit you might try 12.4(9)T7. Do you need the T train code for some feature or some hardware? If not then you might try 12.4(19) in main line code.
Rick
Rick
