6509 Switch utilizing heavy process
IKRAM HUSSAIN
Community Member
We have two 6509 switches, using VSS. When I do sh proc cpu, it shows 70% to 90% utilization, which is too high I think for that kind of switch.
If anyone can help me in finding out, why it's utilizing that heavy process, appreciate it.
You need find all layer 3 interfaces where input queue drop count is incrementing.
If it is incrementing on that port, you need to find out what packet is in input queue by using the command which I mentioned.
6 Replies 6
Yudong Wu
Level 11
Level 11
please post "show process cpu sort | e 0.00"
IKRAM HUSSAIN
Community Member
Attaching the file
Ok, it might be related to ARP packet.
Can you check the "show interface" to see if there is any layer 3 interface (including vlan interface) with a high input queue drop and the drop count is incrementing as well?
If yes,  use "sh buffers input-interface x/y dump" to where those ARP packet come from.
When I run, sh int command on one of the WAN interfaces I get the following message, is that an issue or not
Input queue: 0/75/1874015/0 (size/max/drops/flushes); Total output drops: 0
The drops does not increase on the vlan interface as shown below
It stays at the same number, please let me know, what are the next steps to look into.
