Bookmark
Subscribe
1583
6509E , Sup720(STANDBY HOT) - software crash
ioan_ploscariu
I have one Catalyst 6509E chassis and two SUP720.
The bootup sequence  on SUP 720 (standby hot) failed .
Messages that appear on SUP 720, on the console port indicate o software crash.
How can i resolve this problem?
I don't have a flash card in SUP720.
Thanks for the help.
This is the bootup process:
System Bootstrap, Version 8.5(3)
Copyright (c) 1994-2008 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot executing command: "boot bootdisk:"
Initializing ATA monitor library...
string is bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXH5.bin
Loading image, please wait ...
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################################################################################ [OK]
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXH5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 16-Apr-09 18:55 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x41C67500
00:00:06: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
Firmware compiled 19-Feb-09 13:10 by integ Build [100]
Earl Card Index= 259
00:00:06: %PFREDUN-6-STANDBY: Initializing as STANDBY processor for this switch
00:00:07: %SYS-SPSTBY-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:06: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:07: %OIR-SPSTBY-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 1048576 Kbytes of main memory
Download Start
Download Completed! Booting the image.
Self decompressing the image : ##################################################################################################################################################################################################################################################################################################################### [OK]
          cisco Systems, Inc.
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXH5, RELEASE SOFTWARE (fc1)
Compiled Thu 16-Apr-09 18:49 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x43BF49B0
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC134400BY
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
60 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
%Software-forced reload
14:39:59 EET Mon Oct 29 2012: Breakpoint exception, CPU signal 23, PC = 0x4240FED8
   Possible software fault. Upon reccurence, please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 4240FED8 4240DA8C 42148C1C 42148C48 41FD6768 420216B4 42021710 4096841C 40968E8C 420D8A58 420D4CF4 420D4F10 42402F0C
$0 : 00000000, AT : 43FE0000, v0 : 45B70000, v1 : 44A00000
a0 : 50F07620, a1 : 0000F100, a2 : 00000000, a3 : 00000000
t0 : 42403528, t1 : 3400F101, t2 : 42403538, t3 : FFFF00FF
t4 : 42403528, t5 : 00002D2C, t6 : 40000000, t7 : 00000000
s0 : 00000000, s1 : 43F50000, s2 : 472DBE00, s3 : 0000001F
s4 : 00000040, s5 : 472DBE00, s6 : 45010000, s7 : 00000000
t8 : 5000DBBC, t9 : 00000004, k0 : 00000000, k1 : 00000000
gp : 43FE1B10, sp : 5000DC68, s8 : 00000000, ra : 4240DA8C
EPC : 4240FED8, ErrorEPC : 420DBA88, SREG     : 3400F103
MDLO : 00000000, MDHI     : 00000000, BadVaddr : 00000000
DATA_START : 0x43BF49B0
Cause 00000024 (Code 0x9): Breakpoint exception
Writing crashinfo to bootflash:crashinfo_20121029-113959
========= Start of Crashinfo Collection (14:39:59 EET Mon Oct 29 2012) =========
For image:
========= Show Alignment =======================================================
No alignment data has been recorded.
No spurious memory references have been recorded.
========= Malloc and Free Traces ===============================================
MallocFree Trace: ixmallocfree=0x24 ptr=0x4508A130
4508A010: 52112D78 41AAE2AC 52112D78 41AAE394 511427B4 40000046 511427B4 4141786C
4508A030: 511427B4 41417DD4 51142868 60000022 511427B4 40000046 511427B4 4141786C
4508A050: 511427B4 41417DD4 51142868 60000022 52112D78 3000002A 52112D78 41AAE2AC
4508A070: 52112D78 41AAE394 511427B4 40000046 511427B4 4141786C 511427B4 41417DD4
4508A090: 51142868 60000022 511427B4 40000046 511427B4 4141786C 511427B4 41417DD4
4508A0B0: 51142868 60000022 52112D78 3000002A 52112D78 41AAE2AC 52112D78 41AAE394
4508A0D0: 511427B4 40000046 511427B4 4141786C 511427B4 41417DD4 51142868 60000022
4508A0F0: 511427B4 40000046 511427B4 4141786C 511427B4 41417DD4 51142868 60000022
4508A110: 52112D78 3000002A 52112D78 41AAE2AC 52112D78
00:01:56: %SYS-SPSTBY-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:01:56: %SYS-SPSTBY-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:01:56: %OIR-SPSTBY-6-CONSOLE: Changing console ownership to switch processor
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x43763e54
PC = 0x411873bc, Cause = 0x1820, Status Reg = 0x34008002
Ivan Shirshin
Hi Ioan,
The stack decode show heartbeat_peer_failed - crash due to heartbeat failure. This is usually either misseated supervisor or faulty HW.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
