6513 hanging problem
cavnet
Frequent Visitor
Frequent Visitor
i have a 6513 in the core which is causing few problems
1, you can telnet to it, but if you run commands like "sh run", "sh cdp" "ping"
it hangs
also, if I try and do a "wr net" to my pc, if starts and sends some info then fails.
the cpu and memory are fine, no servers seem to have an issue.
access on the console, and do any (bar wr net) and the system runs fine.
any ideas????
5 Replies 5
Amit Singh
Please paste " show version " from your switch.
-amit singh
here you go
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(17d)SXB1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 28-May-04 19:13 by ccai
Image text-base: 0x40020FBC, data-base: 0x41F38000
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(17d)SXB1, RELEASE SOFTWARE (fc2)
CS-CPSW-W01 uptime is 1 week, 3 days, 19 hours, 37 minutes
Time since CS-CPSW-W01 switched to active is 1 week, 3 days, 19 hours, 36 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 19:33:07 BST Sat Jul 14 2007
System image file is "sup-bootflash:s72033-pk9sv-mz.122-17d.SXB1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6513 (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID SAL081971KH
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
35 Virtual Ethernet/IEEE 802.3 interface(s)
122 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
cavnet
Frequent Visitor
Frequent Visitor
any more info needed??
Can we see the config ?
here is the config
